2002 5.4L timing chain install - Ford Truck Enthusiasts Forums
Old 04-17-2012, 08:45 PM
RandyJ2007 RandyJ2007 is offline
RandyJ2007 is starting off with a positive reputation.
After MONTHS of getting around to it me and my son are ready to put the heads back on his van's motor.
First of all, one of the guide pins (ring) in one head is missing.... reckon it would be safe to install without it by just aligning the head very carefully then tightening down the head bolts?
Is there any reasonable way to install timing chains without having to buy the special camshaft and crankshaft holding tools?
Old 04-17-2012, 10:32 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
You need the alignment dowel. It keeps the oil and coolant passages lined up. you dont need any special tools to set the chains. Go here http://www.ford-trucks.com/forums/70...g-a-5-4-a.html and read my post.
Old 04-17-2012, 10:58 PM
Thanks BUNCHES! Maybe we'll get it done next time we get to the van to work on it....
5.4L secondary cam chain timing marks? Gembone Nevada Chapter 1 01-08-2013 11:14 AM
Best timing Chain? Mild Modifications? 400 chamblizi 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 43 06-05-2012 08:48 AM
timing chain mwkobe Explorer, Sport Trac, Mountaineer & Aviator 14 03-14-2010 09:40 PM
Need help installing a 5.4 timing chain carlos1212 1997-2006 Expedition & Navigator 3 07-08-2009 07:04 AM
4.6 timing chain alignment Jim88554 1997 - 2003 F150 3 11-17-2008 05:39 AM
Tags
2001, 2005, 54, 62, chain, chains, engine, expedition, ford, installation, marks, put, timing, v8, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
