Pulling a Fifth Wheel Camper - Page 2 - Ford Truck Enthusiasts Forums
Old 04-18-2012, 03:42 PM
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
My 2003 F250 is only rated for a 12000# Fifth wheel. Gross cargo weight is where you will get killed. Your 250 is not rated for 15 to 20 percent of your trailers gross weight.
you have to count fuel, hitch, people, tool box, dog etc, in to your gross carrying capacity.
I wish I could recommend that you can tow it safely, It is a beautiful rig.
This may help. http://www.wilkinsrv.com/PDFs/2008TowGuide.pdf
Old 04-18-2012, 05:07 PM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
Quote:
Originally Posted by Franko72 View Post
Here are the specs for that camper, It's pushing it a bit, but It's not a 18k lb trailer.
I also don't know how much pin weight a 250 is rated for.
Franko, look at the Gross weight. Its 18K. dry weight is over 13. I've got that same rig with a slightly different floor plan. It weighs 18.5 rolling over the scales with all our stuff in it and NO water.
Its a heavy rig.
Barney
Old 04-18-2012, 05:45 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Quote:
Its a heavy rig.
Barney
After further review Barney I concur...It is too big for a 250. My Creek is about 13,500 loaded with around 2400 lbs on the pin. After I ran a few numbers in my head (that took a while ) I wouldn't want to tug around my unit with anything smaller than what I have now.
A F450 and a toy hauler is in my near future...
Old 04-19-2012, 06:37 AM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
The rotor size is important, agreed. (heat,grip and leverage) But i believe it is were the rubber meets the road is more of a factor. A dually just has better footing. I have had the trailer brakes locked up and the truck takes up the rest of what the trailer tires (rubber meets the road) can't do. It sure would be nice to have 4 rubber contact points on the concrete on the back of the truck. Especially when the roads are wet. And besides that, "e" rated tires are what, 3000 lbs(approx) each at max pressure? The 3000 lbs heavy pin box takes up most of 1 tires carrying copacity?
Old 04-19-2012, 10:06 AM
MadogLlewellyn MadogLlewellyn is offline
MadogLlewellyn is starting off with a positive reputation.
Hey this is great info from everyone here.... thank you very much!!!!
I have looked at upgrading too bigger brakes and an exhust brake system.... but by the law my truck is only rated 20k GCWR.... you are right I'm way over my rating.... so can I upgrade my truck class offically with doing upgrades like these? Has anyone done that or can it be done?
Otherwise I need to look for a 7.3L F450 rare truck!!! Cuz I'm not sold on the new engine yet tell after it gets some years under its belt!!!!
Once again everyone has made great points.... the truck will pull it do to the legend of this engine... however the brakes worry me... they are smaller than the newer trucks... axles are the same though! So I know my GAWR is not a worry.... The DRW would be nice insurance but I can live without it would be limited towing.... only for TDYs and some summer trips !
Old 04-19-2012, 03:07 PM
Unless you just can't live without the DRV, I think I would shop for a different 5'ver
Old 04-19-2012, 03:57 PM
alexpinca alexpinca is offline
alexpinca is starting off with a positive reputation.
Ford F250 2000, pulling 16k unit 32ft 5th wheel
My truck has pulled me through some steep climbs but there have been a couple of times that I got down to 40 mpr...if you try to pull 20k with this, it better be in top condition or live in Kansas and stay there.
Old 06-19-2014, 09:46 AM
GMUGNIER GMUGNIER is offline
GMUGNIER is starting off with a positive reputation.
I know this is an old thread but I am in a similar predicament and am going to be towing a DRV 43' 18,500 lbs with 3600 on the pin. has anyone considered the safety hitch with airbags? or is there another thread here that I didn't see. BTW my rig is a 2011 F250 6.7 - the only thing I am worried about is will it pull up the Rockies with that much weight? With the safety hitch I am not concerned with stopping, only with will my engine and tranny hold up?
Old 06-19-2014, 10:31 AM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Quote:
I would post your question in the 6.7L forum and the towing/trailer/5th wheel forum. The biggest thing that catches my eye at first glance is 3,600lb pin weight. That's about 1,000 pounds + over payload capacity. That is one heavy load
Old 06-19-2014, 10:36 AM
Old 06-19-2014, 01:02 PM
Quote:
Yes it is, however the safety hitch will handle the weight, and the braking - so on the payload I am not concerned. And yes I guess it would be more appropriate to post in the 6.7 section, however I came across this thread in a general google search and because the question was so similar I thought I would chime in. Will the 7.3 engine tranny pull that kind of weight up the Rockies? (And if the 7.3 can do it - it is reasonable to assume a newer engine and tranny could as well?) If someone has hauled in this kind of steep grade situation, with a heavy 5vr I would appreciate the feedback.
Old 06-19-2014, 01:06 PM
Y2KW57's Avatar
Y2KW57 Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
Please point to the link where this "safety hitch" is marketed.
It sounds like they've figured out a way to defy the laws of physics, and that kind of secret should be held close in the hands of National Security, not running amok in the beds of RV'rs.
  #28
Old 06-19-2014, 01:12 PM
I didn't want to post the link as I thought some here may think I was trying to advertise. - I am in no way affiliated in any capacity with this company.
Here is the link - The Automated Safety Hitch | Trailer Hitch | Gooseneck Horse Trailers | 5th Wheel RVs | Flatbed Goosenecks | Fifth Wheel
  #29
Old 06-19-2014, 01:34 PM
Y2KW57's Avatar
Thanks! I've seen that thing in person when "Mr. Truck" (Kent S.) towed it to the horse expo. I won't call the NSA.
  #30
Old 06-19-2014, 01:54 PM
Ok - so now that we have the weight, and the braking issue resolved. Back to the original question if anyone with info on whether or not these trucks can tote that kind of weight up/down the Rockies or a similar grade without major engine or tranny problems?
Pullrite 2400 - 20K SuperLite ISR 5th Wheel Hitch 17 Oaks Fifth Wheel & Gooseneck RV Towing 14 01-26-2017 06:52 PM
Where does the coolant go? TruckoffFord 6.0L Power Stroke Diesel 11 05-28-2016 09:08 PM
best shocks? TruckoffFord 6.0L Power Stroke Diesel 6 05-15-2016 11:59 AM
OT Trailer for hauling F6 Decisions' opinions jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-07-2011 09:14 PM
F250 V10 or Diesel ? Elmerfud 1999 to 2016 Super Duty 21 08-27-2009 07:45 PM
Tags
43, 60, big, block, camper, drv, foot, ford, powerstroke, pull, pulling, road, towing, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
