1978 F150 4X2 gas to IDI
  #31
Old 10-04-2012, 08:49 PM
minitruckeratheart's Avatar
minitruckeratheart
minitruckeratheart is offline
WOW! that is a super clean install. and that engine! WOW did you powder coat the fuel lines? i love the red fuel lines! and the ford blue engine! thats what i want to do to the engine i have sitting. i plan to rebuild it, and paint it up but didnt know how it would look in ford blue. and now i know it looks AWESOME! great build thanks for all the pics. i cant say enough good things about your build. awesome!
  #32
Old 10-04-2012, 10:17 PM
SnuffthePunkz's Avatar
SnuffthePunkz
SnuffthePunkz is offline
Can't believe I never found this thread till just now. I have plans to drop a IDI into a 78 Bronco. You seem to have found and fixed all the issues that I would run into. Great info.
  #33
Old 10-05-2012, 04:03 PM
kobaltblue's Avatar
kobaltblue
kobaltblue is offline
Thanks, I wanted it to look as factory as I could the fuel lines are just painted to look like spark plug wires...Just take care not to get paint inside the lines....I really wish someone made chrome valve covers! Maybe one of these days I'll get some of it chromed.
Its funny cause people want to look at the truck...
"Whats it got 460?"...
I say no its got a 445
"Whats a 445?"
So I pop the hood nobody figures it out until I tell them its a diesel...
The only thing you need to find is a heavy duty F-350 78/79 radiator I already had one but now days is probably about 500.oo its slightly smaller then the diesel radiator in width to fit between the frame rails,One thing I'd do different is weld up the A/C hole because it wont fit back in so I had to screw a cover over it other then that it works great, Even though Oil Burners told me the engine wouldnt fit and it was a waste of time and money!
The only things not really covered is the wiring but its up to the owner how they want to go about that, I used the diesel glow plug section hooked to my switched key and the computer set apart from my original wiring harness stuff like the ALT is the exact same so its plug and play,So if I wanted to go back to my 78 dash I just pull the 91 out and plug back in the 78 and switch back to the 78 fuel tank (different OHM's) on the fuel gauge,But I like the way the 91 looks especially at night.
77explorerf150
01-13-2019 10:52 AM
kpchambers
2017+ Super Duty
16
10-29-2016 09:10 AM
benmoderow
17
06-29-2010 08:36 AM
needhelp49
01-06-2010 10:50 PM
93PGT
09-20-2006 11:51 PM
Quick Reply: 1978 F150 4X2 gas to IDI
