Brake booster size - Ford Truck Enthusiasts Forums
Brake booster size
Old 04-17-2012, 01:54 PM
Spyderjohn's Avatar
Spyderjohn Spyderjohn is offline
Spyderjohn is starting off with a positive reputation.
Brake booster size
Finally getting around to pulling the old single pot master off of my '66 slick.
I'm adding a front disc setup from a '79 but don't have the '79 master cylinder and booster. I seem to recall that the '79 had a fairly large (think 11") booster so I'm thinking about buying one of these.... 1957-1972 Ford Truck 8" Brake booster 1 1/8" bore master cylinder w/valve | eBay
So a coupla questions arise....
1. Is it a huge deal to change booster size in this application?
2. How critical is it to match the master cylinder and brake booster to the calipers?
3. Am I correct in that the booster size dictates the pressure to the calipers and if so is my answer dependent upon what I intend to haul with the truck?
a bit more clarity of the configuration, Front disc: '79 , rear drums: '66
Thanks folks!
Old 04-17-2012, 01:58 PM
Scifi266's Avatar
Scifi266 Scifi266 is offline
Scifi266 is starting off with a positive reputation.
I would say if at all possible just get the master cylinder for a 79 just so that you know that you staying within the original application
Old 04-19-2012, 12:01 AM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
The '66 Bendix vacuum booster in F100"s was 7", which was matched to the '66 drum/drum setup. M/C had a 1" bore. Bore size also affects braking, altho' in 1966 both manual and power assist brakes used the 1"
Booster got larger as years went by. There have been several articles written on later model truck and hot rod forums about matching booster size with braking capability at the wheels.
With regard to booster size, remember if you get too large, esp. with a 352 V-8, you will have a hard time getting the left valve cover off, altho, you can probably put that 8" on there and get by.
As I recall, a dual diaphragm 8" yields same power as a 9" single
Master Cylinder/Booster for 69 F100 Restomod RStelly76 1967 - 1972 F-100 & Larger F-Series Trucks 1 12-01-2014 05:34 PM
manual to power drum brakes conversion wade67 1967 - 1972 F-100 & Larger F-Series Trucks 42 07-29-2014 12:10 AM
Converting F250 to manual brakes Rusty_Old_F250 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-22-2014 01:34 AM
What brake booster do I buy? ridemx 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-29-2011 06:20 PM
77 Highboy, Which Booster & Master Cylinder?? 30over 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-02-2005 10:01 AM
Tags
1956, 1961, booster, bore, break, cylinder, f100, ford, master, size, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
