Everytime I turn my lights on I pop a fuse the one that has the red and yellow wire going to it. Then my cluster lights don't turn on I can't find a broken wire or anything else. I'm a little loss on where to go from here
Has your turn indicator switch been working normally? The lights are wired through th eturn signal switch, if it has any issues it can mess with all of your lights, also look for wires passing through the frame, that have worn bare.... common problems
