Powerstroke 7.3 problems. - Ford Truck Enthusiasts Forums
Old 04-17-2012, 12:25 PM
Webasto 9.1KW Webasto 9.1KW is offline
Webasto 9.1KW is starting off with a positive reputation.
This will be hard to explain in english for me but I'll give it a try...
My -96 powerstroke has started to missbehave latley.
The engine runs great but suddenly it's like the ignition shuts off for a half second then on again...
It can run well for a while, then this problem starts and it happens a fiew times in a row and then it runs as it should again for some time, etc.
I checked the connection to the "solinoid-thingee" that shuts the diesel and that was a bit wet because the diesel filter was leaking. The filtert is fixed now and I changed the contact after drying it out and for a while I thought I fixed the problem but nope.
Is there any other obvious thing I should look at? It feels like there is som bad contact somewhere around that shut-off-solinoid (I dont know the english term for it...).
sorry bout my english.
/Teo
Old 04-17-2012, 02:26 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums Here is a link to the Power Stroke page, probably better to ask the guys there.
Good luck.
Old 04-17-2012, 02:34 PM
Quote:
Good luck.
Thanks.
/Teo
Old 04-17-2012, 03:52 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is online now
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Try changing the CPS (cam position sensor). They are a common issue for our 7.3s. So when your driving down the road, all is normal, then it feels like the engine shuts down for a second, then comes back to life and runs perfectly normal correct? I would say CPS all day long.
There is a possibility that the ICP sensor could be causing this too. To test that out you can just unplug it and go for a drive and see if anything changes.
The CPS is located at about the 10 o'clock position close to the harmonic balancer. It has one 10mm bolt holding it in. Pull the 10mm bolt out and the CPS is free to come straight out the front. Sometimes you might need to twist it a little to free it up or even use a screwdriver to easily pry it out of it's bore. Installation is easy. Put some fresh motor oil on the o-ring of the new CPS, install into front cover, snug down 10mm bolt, and plug in the sensor.
Go to Ford for the sensor. Don't try any of the parts store sensors b/c they will do nothing but give you problems.
Old 04-17-2012, 06:15 PM
terryknight's Avatar
terryknight terryknight is offline
terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.
i agree with the cps
Old 04-24-2012, 07:26 AM
Physics Outlaw Physics Outlaw is offline
Physics Outlaw is starting off with a positive reputation.
I posted into the powerstroke forum
Last edited by Physics Outlaw; 04-24-2012 at 10:25 AM. Reason: posted in a new thread located in powerstroke
Weird eletrical problems please help!! pat420swed Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 11-30-2015 11:47 PM
fuel solinoid Ozman001 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-25-2013 03:21 PM
-96 powerstroke diesel pump problem? Webasto 9.1KW 1994.5 - 1997 7.3L Power Stroke Diesel 35 02-18-2013 10:38 AM
Powerstroke 7.3 problems. Webasto 9.1KW 1994.5 - 1997 7.3L Power Stroke Diesel 15 04-30-2012 07:05 AM
79 f100 starting problems skotrod1 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-16-2011 07:35 PM
Tags
1996, 2002, 73, 75, 96, common, diesel, driving, f150, feels, ford, issues, powerstroke, problems, shuts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
