1954 F100 Fuel Tank Pickup Line Question
Old 04-17-2012, 09:56 AM
medicpg's Avatar
medicpg
medicpg is offline
My 1954 F100 has a flexible line going into a brass fitting and then a rigid line going into the tank.
Right now that brass fitting is held on the tank by some type of epoxy so it doesn't pull out of the tank. (Not sure if that is the normal way)
My question: Does anyone know of any fittings that will allow me to mount this fitting or pickup tube more securely to the gas tank?
Any suggestions or idea's would be greatly appreciated
Old 04-18-2012, 11:48 AM
Indybeer's Avatar
Indybeer
Indybeer is offline
Here is a link to a pic in my garage that shows the setup on my 54...
Ford Truck Enthusiasts Forums - Indybeer's Album: Garage - My 54 - Picture
I have a hard line into the 45 degree tank pickup fitting. It is screwed into the pick up tube boss. If yours is epoxied in, it was either stripped out or leaking. You can pick up the 45 degree fitting at Mid Fifty...part # 1672 for $5.50
If your pick up tube fitting is stripped you might be able to tap it out and install an adapter for the fitting to screw into.
Old 04-03-2013, 12:20 PM
flamesoldier's Avatar
flamesoldier
flamesoldier is offline
Hey indy beer do you have a pick of other side o fuel line setup im trying to figure out where on the frame it goes and hiw the flex line goes to pump as well
Direwolf23
12-25-2015 06:01 PM
MSgtling
04-06-2015 10:41 AM
pickenspolitics
18
05-31-2014 09:15 PM
Gabacho
16
02-02-2014 01:40 PM
clovejoy
1997 - 2003 F150
10-29-2010 08:54 AM
Quick Reply: 1954 F100 Fuel Tank Pickup Line Question
