17.8 MPG can be done with the V10.
I came across a gas station that had marine grade no ethanol 89 octane...
Sure it costs about .30 more per gallon, but since I was on empty I decided to try 10 gallons.
So after a 40 or so mile run on the (flat) hwy@ 65mph, I got back 17.8MPG.
Hardly scientific, but when I usually see 15 mpg on that stretch of hwy and then I see that, I'm sold.
Try a few full tanks of normal driving and then report back hand-calculated mileage. It is no surprise non-ethanol fuel give you better mileage, but short trips are not a good overall average.
Having said that, I can't wait to try it this summer. I've already mapped out stations that have non-blended fuel where I'm traveling.
Because one or two choices are not enough (sure miss those prices):
According to the this site: Ethanol vehicles running ethanol will typically go 3–4% fewer miles per gallon on E10 than on straight gasoline.
Here is a nice calculator that makes it simple:
http://data.desmoinesregister.com/fu...calculator.php
To be a better deal:
E10 (gasohol) should be close to $3.70 or less.
Price of unleaded: $3.83
So based on these calculations, I would have to pay about $.13 less a gallon in order for E10 to be worth buying.
Gasoline = 114k btu
Ethanol = 112k btu
1.0 gal of gasoline = 1.02 gal of ethanol
Why I won't run ethanol in my V10? Because it is not a daily driver. Ethanol has a weakness if it sits. It absorbs water more the gasoline. If it absorbs water then it will decrease the octane rating below the safe level for engines and cause harm. If I have to add additive, then why bother buying it in the first place.
Gasoline Octane and E10 Ethanol Blend Fuels
Gasoline = 114k btu
Ethanol = 112k btu
Funny thing is, at 4% increase in MPGs, my 17.2 comes out at exactly 17.888, 3% is 17.716
500 mile trip, hand calculated. Usually that run is 16.5-16.8, but I was running slightly slower, around 60MPH, instead of the usual 70.
V10's have knock sensors, so that's not really a problem, as long as 4 degrees of retard can get rid of it, that is.
I've been commuting 44 miles a day, about half of it stop-and-go, and getting 11.
I found a few things that make a world of difference. Even if it's a clogged highway, where you can only get up to 30-40 MPH, as long as there's no traffic lights or stop signs, it helps a LOT. If I take a "short cut" (same distance, but faster overall) that includes lights and stop signs, it drops below 10.
No idling. I usually stop at the beer distributor for 10 minutes twice a week, or warm up the truck in the winter before taking off. If I do that type of stuff, I lose 1MPG easily. Any time that the engine is running and you aren't moving, or have to accelerate back up to speed, there goes the gas.
