Replacing oil pan gasket - Ford Truck Enthusiasts Forums
Old 04-16-2012, 09:03 PM
mr.fordneck's Avatar
mr.fordneck mr.fordneck is offline
mr.fordneck is starting off with a positive reputation.
1990 f150 4x4 5.0. Under the oil pan I have a crossmember. I have about 3 inches of clearence between the top of the pan and the crossmember. Would it be possible to unbolt the pan and slide in the new 1 piece gasket without raising up the engine. I don't want to have to raise the engine up if I don't absolutely have to. Thanks
Old 04-16-2012, 09:33 PM
Nick_lebbad Nick_lebbad is offline
Nick_lebbad is starting off with a positive reputation.
i have done this in a 4.9, it was possible to just take off the old gasket and work the new one in but it is a major PAIN IN MY ***.. i ended up unbolting the motor mounts/tranny bolts from the cross member and took the intake off just to get enough clearance to take the whole pan out.. my local shop shows this as a 6 hour job on the 4.9 4x4.. not 100% on the 5.0's but i am pretty sure its very similar.. especially if yours is 4x4..
you also don't want to take off the old gasket and have all that crud fall in your oil pan.. its better to be able to take it off and clean both the pan and where the old gasket was without the pan there.. and since its such a pain and oil pumps are cheap enough.. i would replace that too while you are at it if you go ahead and get the pan completely out..
just my 2 cents.. yes its possible at least on a 4.9 but it is a pain in the ***..
Old 04-16-2012, 09:38 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Pretty sure you will have to jack up the engine at least a little. Here is a writeup from FSB.com: Oil Pan+Pump Replacment (56K Warrning!) - FSB Forums
Old 04-16-2012, 09:55 PM
Ed Bamba Ed Bamba is online now
Ed Bamba is starting off with a positive reputation.
I did mine without raising the engine, although the transmission was out of the way when I did it. I used the Felpro one-piece silicone gasket. You'll have to bring the gasket up from under the pan, it will have enough stretch in it to do this.
Old 04-17-2012, 05:04 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
My dad and I replaced the pan gasket on his '92 without lifting the engine at all. Clean the outside of the pan rail and old gasket before dropping the pan and you shouldn't have any problems with dirt in the pan. Give the inside of the pan a good wash down with the drain plug removed using brake cleaner or similar and I don't think there will be any problem. The one piece gasket is definitely the way to go. It should take no more than a couple of hours to replace the gasket.
Old 04-17-2012, 11:01 AM
minnesotafisherman's Avatar
minnesotafisherman minnesotafisherman is offline
minnesotafisherman is starting off with a positive reputation.
Quote:
About a 6 hour job on the 5.0 as well, going to have my shop replace the pan and gasket for me in a couple weeks. 4x4 or not, doesn't make a difference. Mine is a 2wd and the engine crossmember is still in the way.
Oil Pan Removal - '84 F250 4x4 351W kr98664 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 02-07-2016 11:37 PM
1997 powerstroke oil pan removal and replacement protracker 1994.5 - 1997 7.3L Power Stroke Diesel 14 10-30-2013 08:12 AM
Changing oil pan gasket on a 71 F100? 240 Six 1967 - 1972 F-100 & Larger F-Series Trucks 1 01-27-2011 07:53 PM
Bronco oil pan removal/install 1pump 1978 - 1996 Big Bronco 13 09-25-2003 09:25 AM
Oil Pan replacement wingham 1987 - 1996 F150 & Larger F-Series Trucks 21 04-19-2003 07:37 PM
Tags
1974, 1996, 30, changing, f100, f150, ford, gasket, oil, oilpan, pan, replace, replacement, replacing, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
