2001 ford f250 shifting issues - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 04-16-2012, 08:16 PM
bowler300623 bowler300623 is offline
bowler300623 is starting off with a positive reputation.
I have a '01 F250 V10 that does not engage park and low1. I cant shift it up to where park should be to turn and remove the key no problem. However... I have to start it from nuetral and use the E brake to keep it from rolling when stopped. Is there a adjustment on the shifter cable or could this be something more serious? What should I check first? Where to start?
Old 04-16-2012, 08:34 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Sounds like a typical "sloppy shifter" caused either by loose/Missing Torx-headed bolts or from a worn-out shifter tube.
Old 04-16-2012, 09:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Crawl under the steering column and look for two Torx head bolts. They hold the shifter tube to the column. They often get loose and cause these problems.
Old 09-14-2015, 01:16 PM
jeffvan jeffvan is offline
jeffvan is starting off with a positive reputation.
I had the same issue, after i pulled the fuse access panel, found a plastic adjuster that had broken. I solved the problem by pulling the cable to correct position and wrapped a small bit of electrical tape around the shift tube. Problem solved.
Old 09-17-2015, 07:00 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
That year F-Series might have the Torx-headed bolts Mark K refers to on the top side of the column, kinda hidden under the instrument cluster.
I'm in process of rebuilding and installing an F-Series tilt-wheel column into my '00 E250---have a few photos of the column removed to share if that's of any use.
BTW those bolts are a T-55 I believe, bushings almost always readily available anywhere parts are sold, about $5 each from the dealer.
Old 09-17-2015, 11:40 AM
They are T-30 Torx.
Instrument Panel Gear Shift Indicator trophy_fish 1999 to 2016 Super Duty 5 04-05-2016 09:05 PM
1988 F-250 Cranking Problems ndanielle1968 1987 - 1996 F150 & Larger F-Series Trucks 0 08-02-2015 09:22 AM
2011 F250 wont shift out of park. apayne1818 1999 to 2016 Super Duty 4 02-10-2015 11:37 AM
C6 will not shift into park whitetrash 1967 - 1972 F-100 & Larger F-Series Trucks 12 09-30-2014 05:48 PM
1997 F 250 5.4 L SHIFT INTERLOCK SOLENOID CIRCUIT PROBLEM jorge995 1997 - 2003 F150 10 06-23-2012 02:41 PM
Tags
2001, 2003, 2008, automatic, f250, ford, issues, problem, problems, shift, shifting, transmission, troubleshooting, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
