Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-16-2012, 04:01 PM
pstroke7_3's Avatar
pstroke7_3 pstroke7_3 is offline
Garage is empty, add now
pstroke7_3 is starting off with a positive reputation.
Death Wobble/Input needed
Hi all, After much research and internet time, I have finally found what I believe to be a cure for my front end wobble. I have the wobble worst on the passenger side at about 46 mph. I have an axle pivot bracket loose, worn pivot bushings, and had treated (I thought) the old girl to a bearing pack and tire rotation the week before this all happened. Turns out, the combination of different tire/worn components is causing this wobble in my case.
What I'm looking for is some guidance. A trusted front end shop in my area said he sees this problem often and supplements the tightening of the bracket bolts with welding of the bracket to the subframe. Is this a good idea? I could only find one post related to welding these brackets and it didn't sound like that person thought it was a good idea. I need ideas on how to stabilize the front end. Looking for a permanent fix, or should I just keep tightening the bolts and inspecting regularly. I know I can count on good info and real world experience here on the forum. Thanks in advance!!
  #2 (permalink)
Old 04-16-2012, 04:38 PM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i would not weld the bracket to the frame. if the bolts will not hold it tight, replace the bolts.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #3 (permalink)
Old 04-16-2012, 06:15 PM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Loctite and nylock nuts are your friends in this situation for sure
  #4 (permalink)
Old 04-16-2012, 07:40 PM
pstroke7_3's Avatar
Is there any specific reason you wouldn't want to weld on these brackets? They wouldn't be welded on so solidly that they would never come off. If I wasn't at least a little hesitant, I wouldn't have posted to the board. I have Nylon lock nuts on the holes that I can use them on. The passenger side bracket has 2 bolts that go in along the longitudinal axis of the vehicle that have a special retainer on the heads as well as a knurled surface that seats into the frame crossmember. Is it kosher to replace these with grade 8 fasteners and locknuts? I probably won't weld on these brackets now that some members have wieghed in on the matter. I can always count on you guys to provide good info. Thanks much!
  #5 (permalink)
Old 04-16-2012, 09:00 PM
bad12jr's Avatar
I welded to my frame for my traction bars before I knew what I know now. It can take the temper out of that steel where its a hardened piece if done incorrectly with out the proper strengthening and fill metal.
Bolts are easier in my a opinion and much less chance of fire.
__________________
Jeffrey
2002 F250 Sport 7.3 Stroke BTS Auto, Adrenaline HPOP, 160cc Singles, RR Fuel, Banks IC, Van charger w/ATS housing, Studs, Crower rods, Gearhead Tunes
1996 F250 7.3 Stroker 5spd Cobalt Pyro and Boost, Gearhead Tunes, 6637, 3" dp to 5" tailpipe, SD electric fuel, SD AD's, T500 HPOP, DIY Coolant Bypass Filter, 3'' plenums, Intercooler waiting for some tubes & time, Valair Kevlar/Ceramic Single Disk.
2008 Escape XLS 4wd 2.3 4cyl. WIFES
  #6 (permalink)
Old 04-16-2012, 09:46 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.
I agree with everyone else, I wouldn't weld the brackets. I'd say some of the other worn parts contributed to the bolts loosening up. Get all the other stuff taken care of and new bolts with red loctight, and you should be good to go..........unless, the bolt holes in the brackets or crossmember are wallowed out, then you may have to drill em all one size bigger and use one bigger size grade 8 bolts to make everything fit snug.
__________________
Bill
'97 F250 ECSB, 4x4, ZF 5spd, 4.10, Rosewood Stage 2s, T500, TS chip, e-fuel, D60 swap, 6637, EBPV delete, CCV mod, 3" dp to 4" straight pipe, Valair clutch, bellowed up pipes, Glow Shift gauges, Scangauge, diy HPX
'92 F350 CCLB, 4x4, ZF 5spd, 4.10, 460 gas to PSD conversion project truck
  #7 (permalink)
Old 04-16-2012, 10:44 PM
pstroke7_3's Avatar
I did not realize the crossmember was a tempered piece. I whole heartedly agree with you guys now that welding may not be the best idea. I know the bolt holes are not elongated, so I will be heading to get some grade 8 hardware, red loctite and a crate of patience to crank these things down again. Then I'll be ready to do the axle pivot bushings when they arrive later in the week. Thanks again to all of you for your help and time. This is the BEST site, hands down, for working on our POWERSTROKES!!
  #8 (permalink)
Old 04-17-2012, 04:42 AM
the brackets are cast metal, and will not stick if welded. you will need different heat settings for both metals, and different rods for both metals. the only thing welding is going to do is ruin the bracket and cross member.
__________________
Tom
Tags
97, addiction, alcohol, crate, curing, death, diesel, f250, gas, issues, motor, mybb, powered, stick, wobble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
