You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have for sale, my 1975 F250 4X4 'High Boy', the 1978 F100 that was going to be used for the body swap. (2) 4 spd standard transmissions, spare divorced transfer case (Part time) Dana 80 Dually rearend, 1.5 ton springs and frame from C3500HD. Dana 44 HD Closed knuckle under the F250. Have a Open Knuckle Low Pinion Dana 44 HD that is just the casing and knuckles that go with it. I have a spare bed, and a bunch of spare front clips and hoods, and sheet metal. I also have a 12 foot section of C-Channel steel, that is BRAND NEW, building grade steel, I was going to use it to make a front bumper but could be used to strengthen the frame. Have the stuff to convert the rear to 'Low Boy' style rear springs, and hint why I have the 1.5 ton springs. I got a ton of parts for this truck, to many to list. I also have sapphire blue paint, and a custom one time only special metal flake mix to go with it.
I am getting rid of them cause between taking care of my elderly grandmother, helping my mom and dad with things around the house, and working 40+ hour weeks, I do not have the time to work on it like I want. It breaks my heart to see it just sit and rust. To top it off if someone came to me with a 7.3 Powerstroke 4X4 or a First/Second Gen cummins 4X4 I would throw in a freshly bored over 460 block, the crank and rods, the new pistons for it, the heads, and anything i have for it.
So either trade for a 4WD Diesel (Chevy 6.5 TD's are welcome!!!) or 5,000 dollars. Maybe a trade for a 3/4 4X4 Gasser and some cash IDK
I am located in Pomeroy, Ohio. Zipcode is 45769. Be for warned, I am not up for 'Negotiations' Its either what I am listed above or nothing at all. PM me if you are interested.
Thank you for reading this.
Edit: So that this is clear, you are getting 2 cabs, 3 front ends, 2 hoods, 2 beds, and 2 TITLES. I was jsut going to put the F100 Body on the F250 frame and just have it titled as a F100, and keep the F250 cab on the F100 frame till I got time to fix it. Anyways this is TWO TRUCKS that WILL NOT be split. Well Unless you wanna pay 5000 for just one truck....
__________________ JESSE: Mobil Mechanic @ Felman Productions LLC
1995 F150 4X4 EC Eddie Bauer 5.0/Auto/4X4/3.31's
1999 F150/5.4/4WD/Auto/3.55's
1979/1981 Chevy K25/350ci/TH350/NP203/4.10's/Full Floater Rear/Camper Special
