Traction bar help
Traction bar help
I've been really looking at a set of ouo trac bars from riff raff diesel. Problem is I don't know which configuration will work best for me? I don't want to weld brackets to my axels so a bolt on would be preferred. Which length would you guys recommend? The adjustable or solid? It's my work truck so daily driver, haul a fair amount of stuff in bed generally pull my tool trailer couple times a month it weighs around 10,000. Truck is a 2010 f350 cc long bed. I've attempted to contact riff raff by phone multiple times always says leave message we'll call back. Never get called back. So looking here for help.
Thanks, Donovan
Thanks, Donovan
With the long bed you will want the adaptable length bars. The small or long gusset is based on what you want visually so it is up to you on that.
Is your truck lifted at all or stock height?
You can do either that traction blocks and replace yours or do the bolt on.
They will function the same but the bolt on is less expensive.
Thanks, Donovan
Thanks, Donovan
Fabricated Unitized Floating Traction Block - Precision Metal Fab
awesome product excellent customer service, trevor is an awesome guy to deal with!!!
Hay buddy if ur not hung on the ouo stuff check out precision metal fab,
Yes,I did the 5.5" traction block lift with 3/4 u-bolts, traction bars and an air lift bag setup in the rear and the 3 link 4.5" lift in the front with bilstein 5160 reservoir shocks all the way around, but I actually only have about a 100 miles on mine. Took all the wrap out from what i can tell, the shudder i had when pulling my goose-neck equipment trailer taken of from a light appears to be gone. No bind from i can tell but i haven't really been in a position to really stretch the suspension that far. I haven't had a chance to clean my truck up but ill be posting some pictures this week. Did all the work myself even did air bags at the same time. So far i really like the setup, if you look on other forums like powerstroke.org or the powerstrokenation, allot of guys are running the setup and are very please. As far as Trevor from precision, great guy to deal with always could get a hold of him even on the weekend, always had the answers i needed to assist with the install.
I can't comment on the PMF bars since I have not run them. But they are a "ladder" style bar that performs different then the style of bar One Up Offroad sells. The "ladder" style is more likely due to design to bind at some point in suspension travel if you offroad the truck.
Your best bet is to contact the builders either One Up Offroad/Clay at Riffraff. I think Clay has OUO bars on his truck. There are also quite a few others on here (Weekendwarrior) who have done a little offroading/beat down on the OUO bars and comment on how well they work.
Remember these bars are expensive but once you get them in the mail, you will understand why. Pictures do not do these justice. The kit is very well put together and worth the extra coin. Essentially you are getting the same bars that are on one of the fastest powerstrokes out there and the same bars that are on jacked up 6-700 horsepower trucks sled pulling!... LOL
There are tons of videos and pictures of One Up Offroad bars in action... here are a few to enjoy, assuming you have not seen them posted before.... LOL It is worth it to explore One Up Offroad's youtube page!!
Denny's truck on 40's with a cummins
Denny Hao Sled Pull - First Place - YouTube
Rudy's truck 9.75 @ 137 MPH
9.75 @ 137 - 4/23/11 - YouTube
Here is David's OUO bars on his truck...
Do your self a favor and get the OUO bars. I have seen to many falures with the PMF bars and other Suspention components an they are very noisy bars when you go in and out of driveways and such. OUO hands down.
Well ifs theres a weak link in the PMF setup im sure i'll find it, my trucks far from a pavement princess
