Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 04-16-2012, 02:24 PM
026TB4U 026TB4U is offline
Garage is empty, add now
026TB4U is starting off with a positive reputation.
2005 Expy P0174 and P0301 Error Code Help
I just got a AutoXray 700 CodeScout and pulled two codes.
P0174 - System Too Lean (Bank 2)
P0301 - Cylinder 1 Misfire Detected
Can I get some advise on how to fix the above codes?
My plugs were changed about a year ago, so I'm thinking the misfire is a bad cop. Not sure about the lean condition.
Any ideas?
__________________
2005 Cashmere Expedition Limited 4x4 5.4L 3V
  #2 (permalink)
Old 04-16-2012, 02:31 PM
5.4T's Avatar
5.4T 5.4T is offline
2002 Lincoln Navigator
5.4T has a good reputation on FTE.5.4T has a good reputation on FTE.
well the lean could be cause by the coil pack not burnning the fuel correctly but it can also be a bad o2sensor check under the truck it could have gotten unpluged mine was.
__________________
  #3 (permalink)
Old 04-16-2012, 03:12 PM
Quote:
I was planning on replacing the COP, so I guess we'll see what happens to the lean condition after that.
Can you tell me where the O2 sensor is? Wouldn't that come up as being bad on the scanner?
__________________
  #4 (permalink)
Old 04-17-2012, 12:25 PM
alloro alloro is online now
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
Bank 2 is the driver's side. There are 2 O2 sensors, one before and one after the catalytic converter. The one before is the one you want to get at.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #5 (permalink)
Old 04-17-2012, 02:30 PM
Quote:
Thanks, I will check that.
I picked up another code today on my way to work. It is:
P0308 - Cylinder 8 Misfire Detected
Also, can someone confirm the cylinder order below is correct?
Radiator
5 1
6 2
7 3
8 4
Firewall
Thanks.
__________________
  #6 (permalink)
Old 04-17-2012, 11:24 PM
Quote:
Radiator
5 1
6 2
7 3
8 4
Firewall
Confirmed, you have it correct. I trust you took notice that #8 is on bank 2!
__________________
  #7 (permalink)
Old 04-18-2012, 09:02 AM
Thanks for the confirmation. I cleared the codes and the cylinder #1 and #8 codes came back. I have not seen the lean condition again, but I am going to check the O2 and change the fuel filter.
How hard is it to replace COP #8? It's way back but it looks unobstructed.
__________________
  #8 (permalink)
Old 04-19-2012, 01:09 AM
A little time and a little patience and it's not so bad. I know you changed them only a year ago but you might want to change the spark plug while you have the COP out, just in case it's a bum spark plug.
__________________
  #9 (permalink)
Old 04-19-2012, 03:09 PM
I replaced Cop #8 last night. A majority of the misfiring is gone. I am still getting some low rpm misfiring but no codes have been returned. I may try replacing #1 since that was the only other misfiring code I received.
The dealer replaced the plugs, so if the COPS don't fix the problem, it is going back to them.
__________________
  #10 (permalink)
Old 04-20-2012, 07:38 AM
Problem solved!!!
I replaced my #1 COP last night. Low RPM misfires are gone and power is smooth all the way up to redline.
Thanks for all the help.
__________________
Tags
2002, code, codes, computer, cylinder, detected, error, expedition, ford, misfire, p0174, p0301, powered, ranger, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
