Speedo Cable Conversion and Cruise Control - Ford Truck Enthusiasts Forums
Old 04-16-2012, 01:40 PM
Yaga1973's Avatar
Yaga1973 Yaga1973 is offline
Elder User - What???
Yaga1973 is gaining momentum as a positive member of FTE.
Hey all,
A couple of questions for you. I've searched the forums and haven't really come up with the answer to what I am doing.
I'm working on converting my truck from a 2WD AOD to a 4WD M5R2 5 speed with the BW 1356 TC. I have factory cruise control and would like to keep it. I know that my speedometer cable will driven by the TC and that is fine and dandy. However, my cruise control currently plugs into the adapter that is screwed inline between my current transmission and the speedometer. I've noticed on most speedo cable connectors that attach to the BW 1356 have an electronic output which I have discovered is the output for cruise control.
So, my questions are these: 1) Do I need to somehow adapt the newer style speedo cable from the BW 1356 to screw into the factory cruise control module adapter, or 2) Do I just wire my current cruise control into the output of the newer style speedo cable at the tail shaft of the TC?
Thoughts? Ideas? Suggestions?
Thank you!
Aaron
Old 04-16-2012, 03:10 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The first thing I would do is see if the old style speedo cable drive gear/housing will slip into your transfer case. The older transfer cases did have regular speedo cables, I just don't know if they will swap in to what you have. Remember the whole housing with the gear and threaded part comes out of the case.
Old 04-16-2012, 03:25 PM
Yaga1973's Avatar
That's a good idea, Dave. I honestly didn't think about doing that yet but will do so when I get the chance. Maybe somebody else has done this and will be able to say yea or nay before I have to. ;-)
Old 04-19-2012, 03:19 PM
Yaga1973's Avatar
Any other comments, tips, pointers, go play in the highway advice? (Just kidding about playing in the highway bit.)
Old 04-19-2012, 07:52 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Quote:
Originally Posted by Yaga1973 View Post
Hey all,
Thank you!
Aaron
What year is the X-fer case? As your cruse control has the speed sensor inline with speedo cable(two part speedo line), your speedo cable should screw into the x-fer case speedo output.
Now if the x-fer case is a 92 or newer, you might have a issue as those trucks used the VSS in the rear axle for speedometer/cruse (all electronic)functions. Some did not have a mounting machined in the x-fer case for a speedo cable and drive. If thats the case, you may want to find a 91 -older xfer case that has the speedo output.
Old 04-19-2012, 07:55 PM
Franklin2's Avatar
I seem to remember someone swapping the output housing also to get the speedo receptacle in a transfer case that didn't have it. I can't remember for sure though, and you would have to make sure the output shaft would also accept the drive gear, I think it slips on with a snap ring.
Old 04-19-2012, 09:30 PM
Yaga1973's Avatar
I have two transfer cases. One has the mounting boss for a speedo and the other is blank. I'll be using the correct tail shaft housing to make sure I have the speedo output. If the output shafts are different between the two, then I'll have to swap that too when I rebuild the sucker.
It's good to know that my speedo cable will fit; that means less stuff I'll have to fabricate.
Thanks to the both of you,
Aaron
speedometer drive gear/seal abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 6 02-24-2014 10:01 AM
I hate using someone elses computer. jarod17 Testing..... 1 06-28-2011 10:57 PM
BW1356 with speedometer adapter Little Foot 1987 - 1996 F150 & Larger F-Series Trucks 11 01-28-2007 08:00 PM
Transfer case tailshaft swap MustangGT221 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-02-2005 07:56 AM
1976 Cruise Control...dealer installed? Autorat81 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-29-2004 03:40 AM
Tags
1980, 1983, 87, buick, cable, century, control, conversion, cruise, diesel, f250, ford, located, location, speed, speedo, speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
