turbo advice 97 f350 - Ford Truck Enthusiasts Forums
Old 04-16-2012, 12:21 PM
DAN-D-DIESEL97 DAN-D-DIESEL97 is offline
DAN-D-DIESEL97 is starting off with a positive reputation.
i have my 97 f350 powerstroke and i think the turbo bushings are going bad.when the engine is cold,at about 1900 rpm there is a slight screeching sound,i am sure its the turbo.whats weird is after the engine gets good and warm,the noise goes away,and doesnt do it at all.turbo always seems to spool up no problem,even when this screeching happens.i am thinking of getting a kit from riff raff,and doing it myself.im pretty sure i am going to answer my own question on this,but does anyone have an experience where you cant rebuild the turbo?any questions or advice are greatly appreciated !!
Old 04-16-2012, 12:36 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
They can be rebuilt. But depending on what is hosed up I would send it off to a rebuilder who can set it up and get it balanced properly. Or just swap it for a rebuilt one. Depends on your budget and expertise. These kind of things are above my pay grade and comfort level. Not that you couldn't DIY. But I don't recommend it.
PM me as I have a rebuilt turbo I might part with. I would need the core though.
Old 04-16-2012, 12:39 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Just pull the air intake and see what you have on the turbo for shaft play. A little up and down movement is ok as long is it doesn't touch the housing (that may be what your screeching sound is) but you should have no in/out play in the shaft at all. Also for your screeching sounds does it do it when sitting still as well? May be a serpentine belt idler bearing going bad. If it does it sitting still I would look at the idler pulleys instead of the turbo.
Old 04-16-2012, 12:52 PM
tried the end play thing,and i cant feel any in out,or side to side,as for pulleys,ive changed all including belt and tensioner.i did all that when i had the motor out to do the oil pan.ive almost convinced myself that its the turbo,though.this truck has 240k,always changed oil religiously,and am the original owner.
Old 04-16-2012, 01:04 PM
The first couple times I checked for end play I couldn't feel it either. Turns out I wasn't wiggling herd enough. It really surprised me how much force it took to make it move.
I would start looking at the idler pulleys if it were me. If you can duplicate the sound standing still that is. Not much boost is created without taking the truck out on the road and putting some load on the engine, so I would tend to think it was something other than the turbo.
But then again, I have been wrong before....
Old 04-16-2012, 01:10 PM
i appreciate the advice,i will take off aluminum intake tube as to get a better grip on the turbo shaft and give it a good pull and push.my paws are a little big to get a good grip on it with the tube in the way.thanks!!
Old 04-16-2012, 01:28 PM
If you do find it to be badly worn, the rebuild kits can be purchased from Riffraff Diesel and they also carry the replacement inducer wheel. The whole thing can be rebuilt yourself if you have the time and patience to do so.
Old 04-16-2012, 01:30 PM
time and patience i do have,800 bucks for a reman i do not.thanks!
Old 04-16-2012, 02:18 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Quote:
LUCKY! I lack in the patience department..
I would agree with Nate if it screeches at a stand still then it aint your turbo.
I mean your turbo can still have problems, but it aint causing the screeching at a stand still.
Pulleys screech like bats! lol
Old 04-16-2012, 03:38 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Take the belt off and start the truck and see if the noise goes away
Old 04-17-2012, 07:44 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Call me crazy people but i believe he is hearing the exhaust backing up when it is trying to warm up...ya know,the valve that is supplsed to do that...sounds like to me...
Old 04-17-2012, 09:01 AM
I wouldn't describe the sound made by the EBPV as screeching sounds, but I guess that could be possible. Easy enough to test the theory, just unplug the connector for the EBPV under the intake side of the turbo... If it doesn't make the sound anymore you have found the culprit.
Old 04-17-2012, 09:08 AM
been there with the ebpv,that makes a low whooosh sound.odd,my truck did not do this today when i drove it.no squeal or screech.i will do the the belt thing on the weekend.thanks!!
Old 04-17-2012, 03:41 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
I've never heard a turbo "squeal" or "screech". Even one that the compressor wheel was actually hitting the housing and ended up grinding the compressor wheel down probably 1/8"... That's about the worst shape I've seen a turbo and the journal bearings were about gone, but it still made no screeching sounds or anything. Just didn't make as much boost as it should have and spool time was suffering.
I would suspect a pulley before the turbo.
Screeching sound from engine area! drizzie27 1967 - 1972 F-100 & Larger F-Series Trucks 19 06-09-2012 10:46 AM
She's Screeching. WTH? LittleRadio Excursion - King of SUVs 11 04-10-2011 01:12 PM
High pitch screech Bitter Salt 1999 to 2016 Super Duty 5 09-17-2010 10:59 AM
Screeching sound and spinning sound when shutting down medici78 6.0L Power Stroke Diesel 5 06-25-2005 07:31 PM
Loud screeching noise! cwh82 Explorer, Sport Trac, Mountaineer & Aviator 3 10-30-2003 04:04 AM
Tags
1995, 1997, 350, 400000, 73, 97, boost, cold, diesel, f250, ford, loses, screeching, sound, start, truck, turbo, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
