Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Replace Powertrain Control Module
Step by step instructions for do-it-yourself repairs
ECU / PCM replacement
#32
#33
Guys working on this truck has really expand my patience limit.
So far I have checked
- GPR all connection measure 12v even checked pin at PCM WTS comes on.
- all sensors connected CELL turns of when switch on
- fuses chkd incl 22 heater bowl removed.
The 3/4" nut on the solenoid is hard to get to tight do i need to remove the fuel bowl to this?
Do I need to test on the psi on the engine if the sensors are working ok?
I will probably go over all the steps and make a resume to see if I may have skipped a step but so far I have chkd all advices received.
Any other input or suggestion.
Standing by. Thanks for the support guys FTEF
#35
#36
Hey Nate,
I have may forgotten about the CPS probably at first. I ignore it actually since I knew that I replaced it in the beginning just when putting the truck to run the first time. But I've understood that their life time are unpredictable and can fail at any time even when its one month old?
Ok so I have measured according to the prev link and got the following
Pin A 3.5 ohml; B 585 ohm; C 2860 ohm. I guess my CPS had failed since the beginning.
Any other info on this subject of CPS?
#37
#38
I was looking online for any original to order from the US but difficult to get one most are the standard ones.
I will keep on looking.
Thanks Nate
P.S.: Can you reach me on this email please dynacontractors@gmail.com
Thanks Nate
#39
Nate I found a cps at this looking after reading about the cps on a thread of yours
Wells Camshaft Position Sensor SU2161
I have asked if this is compatible with the F7TZ-12K073-A and they said yes.
I found a international one but this one is "pica pica"
1807339C92-NAVISTAR-SENSOR
I guess I will start get the above mentioned first to get the obs running and later order one of the international ones
#40
#41
Here is a Motorcraft one for $25. I don't know anything about this place but I would rather gamble on the suppier than on the part itself.
Ford 7.3L Powerstroke Diesel Cam Position Sensor CPS
Also, the C92 sensor you linked to is actually for a Navistar DT466. It is supposed to work, but it is a different sensor for a different engine and works differently than the one for the T444E (7.3 Powerstroke).
From the part number thread:
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96
(Ford) F7TZ-12K073-A 97+ >>
(Ford) F4TZ-12K073-C 94-96 cheap>>
(Ford) F7TZ-12K073-B 97-03 cheap
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
(International) 1807339C92 (DT466 CPS, reported to advance timing, and stronger signal)
Camshaft Position Sensor (CPS) O-Ring
(Ford) F81Z-12B615-BA)
(International) 1824948C1
What year is your truck again?
#42
#43
Milwaukee1979F150
06-28-2011 11:02 PM
1997F-350
22
06-04-2010 08:07 PM
