Annoying Rattle/Vibration under driver's side dash - Ford Truck Enthusiasts Forums
Old 04-16-2012, 10:23 AM
gdubia gdubia is offline
gdubia is starting off with a positive reputation.
I have a 2001 F-150 Supercab with the V-6. This past weekend it developed some strange noise best described as a rattle or vibration that sounds like it is coming from under the driver's side dash possibly somewhere right behind the instrument cluster. May even sounds a little like a "grinding" noise - like two plastic gears not agreeing with each other, but I don't know of anything under there that could make that noise. I have opened the hood and listened from there with my wife pressing the gas to make the noise start, but can't hear anything from outside the truck.
It is not constant, but starts as soon as I give it a little gas, even before I put it in drive. It's a little worse when it is in drive. I have turned the air on and off, turned the steering wheel, pressed the brake, etc, and it doesn't appear to be related to anything obvious. I have stuck my hand under the dash and can't find anything obviously loose. Has anyone else had this problem? Any ideas would be appreciated.
Old 04-16-2012, 05:23 PM
Dave G. Dave G. is offline
Dave G. is gaining momentum as a positive member of FTE.
What happens with the blower on ? Or off ?
Dave
Old 04-16-2012, 05:25 PM
OK, I see you tried the A/C, so maybe the blower isn't involved.
Dave
Old 04-16-2012, 05:36 PM
Might be vacuum related if it gets a little worse when put into drive (or any other gear).
Try unplugging vac lines, one at a time, and see if the noise goes away ( especially anything on the firewall, under the hood or the dash). Also, if it was vac related, tap the gas pedal a few times to get the RPM's to jump to 2500-3000. The vac will drop pretty low then, so if something is ruptured, the noise should momentarily cease.
Dave
Old 04-16-2012, 06:48 PM
It is mostly quiet while just idling. It "rattles" upon start-up. It is at its worst during initial acceleration from a red light - so you could be onto something with the vacuum. When driving, the noise pretty much goes away as speed goes up, almost like it is reaching a "harmonious frequency" of some kind. I'm going outside to look under the dash again.....
Old 04-17-2012, 08:52 AM
So I figured out what the noise was. The large bracket bolted to the exhaust manifold on the driver's side with a large eye-hole at the top.
Story: All of a sudden the noise just stopped. When I got home and looked for it, I popped the hood, and the broken bracket was just laying there on top of the frame. Amazing that it stayed there until I got home or I may have never figured it out.
There is one on the passenger's side as well. I don't know what these are for, but they seem to serve no purpose. I assume they are for lifting the engine in and out and are just left there after initial engine installation. It does seem a bit strange to me that a bracket to hold that much weight is bolted on with one exhaust manifold bolt on each side so if this is not what it is for, can someone please let me know.
Old 04-17-2012, 10:14 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
THey are for lifting the motor. Remember steel has a tensile strength of 20,000 pounds per inch. A 3/8 inch bolt will easily hold a ton of weight. Your motor probably weighs 500pounds. Couple small bolts would easily pick it up. Parts get lighter and cheaper every year... or at least cheaper !
Old 04-18-2012, 12:30 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Heat sure does strange things to stamped steel parts.
Old 04-18-2012, 08:41 AM
Yeah, it broke above the bolt hole where it connects to the exhaust manifold - really in a strange place and it seems to be of no consequence. More importantly, it is nice to know that I can come on here and post some off the wall question and there are people that can answer it take the time to do so. Thanks everyone.
Old 04-18-2012, 06:21 PM
Papa Tiger's Avatar
I have seen stamped steel mounting parts for air cleaner assemblies that were 1/4" thick crack simply mounted above a hot hyd tank on a tractor. Hyd oil maybe 250 degrees. Not just once but many times. I put it down to inferior China steel. LOL
Rattle at 55 driving me crazy hasteranger Excursion - King of SUVs 15 11-20-2016 12:10 PM
chuffing noise? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 09-29-2015 10:13 PM
Rattle at Idle - Intermittent kenmandoo2 2007 - 2014 Expedition & Navigator 0 11-27-2014 08:27 AM
Funny Noise mlott2112 Excursion - King of SUVs 13 11-11-2012 07:16 PM
random front end growl seaspray 1999 to 2016 Super Duty 10 01-14-2007 03:15 PM
Tags
03, 2003, dash, drivers, escape, f150, f250, ford, hood, ratle, rattling, reading, side, stop, test, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
