Drive Shaft Clicking Noise? - Ford Truck Enthusiasts Forums
Old 04-16-2012, 10:18 AM
MickeySully MickeySully is offline
MickeySully is starting off with a positive reputation.
My buddy has a 2011 250 and is having some weird issues with a clicking noise. It started out when you put the truck in gear (D or R) and touch the gas it would click. Seems to be coming from the middle to rear part of the truck. Now it clicks when he's driving. This all started after he got 35's and a leveling kit. It's taller springs in the front and added a block in the rear. Any suggestions? It has less than 15k on it.
Old 04-16-2012, 11:14 AM
los341's Avatar
los341 los341 is offline
los341 is starting off with a positive reputation.
Quote:
Sounds like the U-joints are going out. Lifting the truck puts the U-joints at a greater angle, which shortens their life. The clicking is probably from bad roller bearings in the U-joint caps.
Carl
Old 04-16-2012, 12:14 PM
CornTruckDriver's Avatar
CornTruckDriver CornTruckDriver is offline
CornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud ofCornTruckDriver has much to be proud of
Quote:
Carl
I second that. I think the max angle is 3 degrees.
This is interesting.
http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
Old 04-16-2012, 12:35 PM
From a 2.5" front lift and a 1" rear block? I can't believe that other trucks aren't having this problem? What's the easiest way to check the U Joints?
Old 04-16-2012, 12:45 PM
Even though the trucks are high, I believe stock the output shaft of the trany points directly at the pinion of the rear end.
Old 04-16-2012, 12:49 PM
Maybe the joint has just setup a ware patern and the change set it over the edge.
Old 04-16-2012, 12:59 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
I have 34k on my truck and I run a leveling kit in the front and 35's. No issues here...
Old 04-16-2012, 01:05 PM
Thanks. Another bit of info. He told me he laid under the truck while a friend drove forward and backwards over him (about a foot in each direction). He said if he put his hand on the drive shaft that he could feel it "ping" which was making the clicking noise.....
Old 04-16-2012, 01:17 PM
SavageNFS's Avatar
not a WHITE truck
U joints...time for new ones. If it doesn't go away after replacing them, check the drive shaft for being out of balance.
Old 04-16-2012, 01:21 PM
I should know this but don't....What's the best way to check the U Joints?
Old 04-16-2012, 01:26 PM
SavageNFS's Avatar
not a WHITE truck
Old 04-16-2012, 01:27 PM
SavageNFS's Avatar
not a WHITE truck
Old 04-16-2012, 01:39 PM
los341's Avatar
That definitely sounds like U-joints to me. I've had them go out before (not on this truck) and had the exact same symptoms.
Carl
Old 04-16-2012, 10:44 PM
jrtraderny jrtraderny is offline
jrtraderny is gaining momentum as a positive member of FTE.
Try lubing the driveshaft spline first.
Old 04-17-2012, 10:38 PM
gelato583's Avatar
gelato583 gelato583 is offline
gelato583 is starting off with a positive reputation.
I have the Same problem on my truck. I have 43 k on it and it's stock. When I hit the gas everything is fine. When I get off the gas there is a sound of rocks hitting metal under the truck. I asked the dealership and they said its coming from my driveshaft. But they drove an identical truck With the same problem so they told me its normal.... I don't care what they say this shouldn't be happening. Any clues on this?? Should I try replacing my driveshaft u joints???
Explorer Rattling Under the Dashboard jamelton Explorer, Sport Trac, Mountaineer & Aviator 1 11-20-2014 08:30 PM
Clicking noise TheProfessorofTOOL 1997 - 2003 F150 1 12-26-2013 09:15 PM
Clicking noise from fuse box TheProfessorofTOOL 1997 - 2003 F150 1 12-26-2013 05:01 PM
clicking noise, either inn rearend or around transmission weaver79 1997 - 2003 F150 4 11-18-2010 01:08 PM
Rear Differential Clicking Flaw 1997 - 2003 F150 9 07-25-2008 09:30 PM
Tags
2001, 2011, cab, clicking, crew, driveshaft, driveshafts, driving, f250, ford, metal, middle, noise, straight, tick, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
