F 150 Specifications
Old 04-30-2003, 10:31 PM
Roadblock7905's Avatar
Roadblock7905
Roadblock7905 is offline
Post F 150 Specifications
i am looking to find the factory specs covering info such as rear end ratio and such. my truck is a 5.0 litre f 150 with a "aod" transmission. for some unknown reason this trucks top speed is 85 mph. can anyone explain to me why it will only do 85 mph? and where i could go to find factory specs? thanks for your time
Upper Case Edited out by FTE
Old 04-30-2003, 10:38 PM
BBiffle's Avatar
BBiffle
BBiffle is offline
You can look at the metal tag hanging off of the rear end to find the ratio of the ring gear and pinion.
Old 05-02-2003, 10:33 PM
PMD66's Avatar
PMD66
PMD66 is offline
Interesting... my 92 302 E4OD Flareside buries the needle. At least in indicated 90MPH and it seemed to have more to go. Running 235R15s.
The tag on the door has axle codes. H9 is a 3.55 LS.
Old 05-02-2003, 10:49 PM
cedarratt's Avatar
cedarratt
cedarratt is offline
I have a 93 f150 5.0l (302) and have noticed that it will not go over 95 I think that it my have a electronic governor of some kind to prevent transmission problems. but I am not sure
Old 05-02-2003, 10:52 PM
PMD66's Avatar
PMD66
PMD66 is offline
I understand the compooter is programmed to limit top speed to around 85- 95 MPH. If you cruise the site long enough, you'll see the others saying this and that a new chip is the cure....
Old 05-02-2003, 10:54 PM
pfogle's Avatar
pfogle
pfogle is offline
my 92 E150 (351, E4OD, 3,55 open diff), runs well over 125 mph.....
Lowered IQ
18
02-20-2014 11:28 PM
85MD
2004 - 2008 F150
07-26-2011 11:24 AM
f-150 on 22's
2004 - 2008 F150
10-09-2008 08:33 AM
Steve(ON)
09-05-2006 01:03 AM
alwaysmessedup
10-22-2002 02:37 AM
Quick Reply: F 150 Specifications
