Backup sensor issues - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-16-2012, 05:54 AM
Powerstrokin_350's Avatar
Powerstrokin_350 Powerstrokin_350 is offline
Powerstrokin_350 is starting off with a positive reputation.
I have a good one for you all, I hope someone can help me. 2005 Crew cab lariat. Heres the story, Start the truck and most of the time the indicator light in the switch says theyre on and operating. Once it goes into reverse they automatically turn off every time. 5% of the time while in reverse I can hit the switch and they will turn on and operate. Once I put the truck into park, or drive, I can always turn them on as well. Here is a scenario (usually its this way, these are the majoritys here) Start up, sensors on. Reverse, off. Place into drive or park and hit switch, they will turn on according to the light in the switch. Place back into reverse and they are off again and I wont be ably to turn them on. Complicated... I hope you can understand that and break it down into something that is diagnosable... Thanks in advance
Old 04-16-2012, 06:19 AM
rattleNsmoke's Avatar
rattleNsmoke rattleNsmoke is offline
rattleNsmoke is gaining momentum as a positive member of FTE.
Sounds like you have a bad sensor. If one goes bad, it trips the system to shut down. Here's a tip......Take a stethoscope and listen for a distinct 'click' sound from each of the sensors with the truck in reverse (Engine off-key on, parking brake on of course). No click or faint click = bad sensor. Good luck.
Mike
Old 04-16-2012, 11:21 AM
PupnDuck PupnDuck is offline
PupnDuck is gaining momentum as a positive member of FTE.PupnDuck is gaining momentum as a positive member of FTE.
Something else to consider: the system disables the back up sensors when you shift into reverse if it thinks you have a trailer connected. It could be a problem in the backup sensor controller OR the trailer brake controller or wiring.
Old 04-16-2012, 08:59 PM
So I turned the ky on, engine off, trans in reverse, waited for all the pumps and other things to quit making noise, and sure enough, I hear clicking (faint clicking) out of three out of the four sensors. Problem solved!!!! almost... I called the local stealership to see what one would be worth... $198!!!! EACH!!!! Are you F'n kidding me???? its a little pos hunk of crap I can get for $20 from a wreckers? Ya kno its cheaper to pick up a complete bumper with sensors off a parted out truck on kijiji?!?!?! Anyway, I know the solution and now I just have to find the way I will go about doing it. Thanks for the response, as speedy as it was as well as accurate!
Old 04-17-2012, 07:48 AM
try RockAuto Auto Parts
It's $91 there.
Mike
'01 Escape Stuck in Park; safety interlock gary7388 Escape & Escape Hybrid 35 12-22-2014 05:19 AM
Rear Parking Sensor Help pokeycameron 1999 to 2016 Super Duty 3 01-02-2014 08:39 PM
Backup Sensors Ironhide Excursion - King of SUVs 8 12-24-2012 05:01 PM
Back-up sensors turn off when put in reverse. Rushmore X Excursion - King of SUVs 12 05-09-2012 10:15 PM
Turning Off Rear Parking Assist Beach_Bob 1999 to 2016 Super Duty 5 04-24-2011 10:27 PM
Tags
04, 2008, 64l, back, backup, check, connect, expedition, f150, ford, issue, reverse, sensor, sensors, show, transit, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
