how do you set timing
I see you have two threads going here, this and the 351w swap.
Who did the work on this engine?
Anyone--friend, shop, neighbor etc--who does work on an engine is responsible for completing the job. If they don't know the engine, they shouldn't do the work. Whoever did this work needs to stand behind it and fix it, or pay to have it done.
i just had another buddy of mines dad give me a 5.4 today witch is very clean the motor ran when pulled i know for a fact the reason it was pulled is because it had a miss. the engine itself is is all ther minus intake it was in his shop no corrosion or anything its very very clean for being used and my mechanic buddy is at work right now
the heads were pulled today and look freshley shaved and the valves are my main concern im getting a valve spring puller tomorrow to see if there fine or not the vavles are white looks like it was running lean the heads them selves were just put on it looks like the pistons on it are very clean with very little carbon build up on them the engine itself i was skeptical about at first but once i started tearing it down i can't find really anything wrong with it i mean even if it was screwed its not a big deal because it was just given to me ill post pics up asap also followed everyones advice picked up a hanes manual
