6.9L diesel any good?
I'm 3 weeks from graduation. I bought this truck in October for $1400. Decided it needed an oil change (back in october), bought everything for it, but didn't get around to it until last week. Decided it needed a clutch kit, bought one in November, still sitting in my garage. Decided it needed new valve cover gaskets, and still haven't done that either. It needs new brakes, but I haven't had the time to tear into it.
In the last few days, the brake booster has failed completely, the pads have completely gone (Grinding now) and my clutch pedal has stopped returning all the way.
I did actually put new glow plugs and a return line kit in back in November.
I also wired in a glow plug control button and installed a new ignition lock cylinder, both because they left me stranded and it was either fix it or ride the bus 4 times a day.
That's about all I've done in terms of repairs.
The windshield is cracked in two places, it leaks oil out of about 4 different spots, the body is beat to hell, and the bed actually sits 3" higher on one side when you look at it on level ground. The windshield seal drips onto the passenger's knees and the radio doesn't work. Nor does the speedometer. Same story on the speedometer, bought a new gear, haven't installed it. I've been driving this truck in this state since I bought it. Just goes to show that they don't die.
But hopefully you'll buy one that's in better shape than this one was.
Yes, I'm still driving it.
ok thanks, he did email me back so hopefully Ill go take a look at it tomorrow or the next day and get an idea of what it needs and what its worth. He said he just bought it a month ago from the second owner and its more truck than he needs, so Ill see what I can do.
Yeah Im new to diesels so Im not real sure where to begin but I have a few friends that have diesels and they know a good bit about them, maybe no so much the 6.9L but One friend has the 7.3, couple others have the 6.0L, and then I got a friend with a duramax and a cummins.
heres the guys ad for his truck. Im going ot try to get some more pics of it today, ad says 113K miles which I dont believe is too bad, But I wanna check the odometer and the title to see if its more like 213K
http://morgantown.craigslist.org/cto/2958584596.html
Well, at least you might be able to fix the F150 if all else fails, lol.
It doesn't look bad but that is only one picture and from far away. I have seen some really nice looking trucks in ads only to get there and find out the other side has been hit or the interior is trashed, etc. Funny how sellers forget to photograph the bad spots.
Either way, it would have to be a real peach to be worth his asking price. Maybe he will come down or it really is a peach. I'm interested to find out.
yeah hopefully Ill go see it today, looks like it has an after market bumper with built in lights and a billet chrome grille like what Ive been wanting to get for my 150. I can tell if its in the back ground either but it might have a single stack. I HATE stacks, first project would be changing it back to normal out the back exhaust.
So here are the pictures,
Body:
Bed is a little rough, If I get it Im just going to swap my bed onto it, front fenders are fine, hood is a little rusty but he said he has another hood for it. Also has the original grille, drivers side floor board has a big hole through it, needs patched up. frame is In really good condition, was just undercoated by the previous owner. rear shocks-covers are rusted away.tailgate is bent all up, but still works, I would just swap mine on.
Tires:
Tires are about half tread or less (265/75/R16)
Interior:
Interior is pretty clean, stock radio, Has it to push button start. has plastic floor mat, not carpet, Id rather have that though carpet holds moisture against the floor. What really concerns me is when I was driving it, when I hit a big bump I could feel the pedals move around which leads me to believe the fire wall is rotted, how bad is this?
Engine:
Engine doesnt sound too bad, but IDK what to listen for. Valve covers leak oil, Has new radiator and dual batteries (not new but fairly new). pretty gunky under the hood though, said it doesnt leak much oil maybe a qt every 2 weeks.
Guy said he could go $2500 for the truck, spare hood, grill, and doors. Also a 1988 300-six engine ZF 5 speed and 1356 transfer case. truck has 113K on it, it will need tires probably before winter and a couple hours of swapping parts and several hours of body work and paint. What are peoples thoughts on it?
Body:
Tires:
Interior:
Engine:
on
1 Post
Looks a little rough for 2500. Mine was 1700 and it looks a lot better, body wise, than that. Than again, if the frame and drive train are solid, than it might be worth it. My tranny is shot, so it about equals up. The interior looks great. The body sure needs some help though. I'd say, if the drive train works good and is solid, than I would go for it. Man I love that stack.
#28
#29
Ok I appreciate it, For that price though he is including the other 300 engine 5 speed tranny(not mazda) and 1356 borg werner (i think thats the number) transfer case. also with a spare hood and doors, but my biggest problems are I know knowing about maintaning diesels or anything and that the fire wall might be rotted out
