Quad 7-Inch Headlight Grill
Old 03-04-2014, 10:09 PM
paredneck33's Avatar
paredneck33
paredneck33 is offline
Yeah I wanna see this happen too. Not really my cup of tea, but would love to see how it turns out!!!
Old 03-04-2014, 11:39 PM
Xauterus's Avatar
Xauterus
Xauterus is offline
Maybe some 5" inner head lights?
Old 06-30-2014, 02:47 PM
buckin69bronco's Avatar
buckin69bronco
buckin69bronco is offline
Bringing this back from the dead...
Over the weekend I converted from a 79 grill setup with square lights to a 77 and earlier set up. I then modified a second set of round headlight buckets that now mount inboard of the original set to have quad lights (sorry no pictures right now, I'll take some tonight)
The second set of lights mounted fairly easily. The mounting tabs needed to be cut off, shortened and welded back on and I was only able to use 3 bolt holes on each side but they are in there and fit (no wiring yet)
Does anyone have suggestions for the grille insert? The original posted picture is cool but that would be hard to make from an oem plastic insert. I have though expanded metal but can't decide.
Old 06-30-2014, 03:32 PM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
I am thinking about making some grille inserts from bar grating (industrial walking surface). I just need to look at a few styles, lots of different materials and spacing a out there.
Old 06-30-2014, 04:45 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
TIG-weld aluminum bar stock to vertical support members.
A honeycomb insert (ala early Mustangs and 05-14 Mustangs) would fit the theme.
.. I wanna see them pics of quad 7s !
Btw, I picked up a pair of 73-75 inserts and will do the mod one of these days... too many projects in the pipeline right now to "play".
buckin69bronco
That is a "grate" idea!
Old 06-30-2014, 07:38 PM
brian1080's Avatar
brian1080
brian1080 is offline
Use some of the plastic style lenses and you wouldn't need as much support for the extra set. glass ones are heavy
Old 06-30-2014, 09:10 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
There appears to be enough room to mount another set of buckets inboard of the originals. Once that is established, a piece of sheet aluminum could be fashion behind the grill and painted black to offer support to the grill.
I have a square tubed grill insert (77&79 loves em) that could easily be reworked for this.
But....imo, this is like test tube research on embryos trying to isolate and grow a midget baby. Its cool that someone finally does, but should they?😳
Old 06-30-2014, 10:06 PM
HIO Silver's Avatar
HIO Silver
Do you mean plastic headlamp units?
That's a good idea... But I'm one to use an extra set of buckets so the inboards are adjustable.
Old 06-30-2014, 10:13 PM
brian1080's Avatar
brian1080
yes. you could even spray tint them so they are less visible when not in use, make them blend with the grill
Old 06-30-2014, 10:58 PM
HIO Silver's Avatar
HIO Silver
Here's a quick Photoshop of a quad 76-77:
Old 06-30-2014, 11:16 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
And since you are good with photo shop, what would 77 lights on a billet grill, in a '79 look like?😏
  #28
Old 06-30-2014, 11:46 PM
HIO Silver's Avatar
HIO Silver
Do you mean 77 round headlights with a 79 "big mouth" insert?
  #29
Old 07-01-2014, 12:01 AM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
Um, big mouth? Im offended.
I have a square horizontal tubed insert. I will post a pic of a truck with it...
  #30
Old 07-01-2014, 12:06 AM
HIO Silver's Avatar
HIO Silver
The grill insert... not yer choppers!
Post a head-on shot like above... It's easier to work with a flat plane.
Quick Reply: Quad 7-Inch Headlight Grill
