injector,standpipe, dummy plug install questions - Ford Truck Enthusiasts Forums
Old 04-15-2012, 08:35 PM
quackrz quackrz is offline
quackrz is starting off with a positive reputation.
So I am replacing #1 injector and while I am in there I am replacing the standpipe and dummy plugs, stc update etc. So I have some questions
1. What is the best way to clean the cup? I saw on youtube, they used a brush. Is this a nylon brush?
2. what is the torque on the dummy plugs and standpipe?
3. I know the jam nut on the stc is 49 ft/lbs but what is the torque for the 2 bolts to the branch tube
4 What is the torque on the hpop cover?
Thanks
Old 04-15-2012, 09:14 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Here's a link to the torque chart, more on the next page also(link at bottom of first page):
Page 84: Appendix: Special Torque Chart A-L
The cup is stainless so you can pretty much use whatever you like. Shouldn't be nothing but fuel in there. A piece of paper towel and maybe a screwdriver? You'll see better when you get it out.
Old 04-15-2012, 10:12 PM
mohle's Avatar
mohle mohle is offline
mohle is starting off with a positive reputation.
What year of truck? Newer models have different high pressure oil rails. There is also a torque sequence for them. If you are going that far, I would also change the STC fitting.
Old 04-15-2012, 10:16 PM
dlibson's Avatar
dlibson dlibson is offline
dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.
He said he was doing the STC fitting...
Looks like your covered on your other questions though...
Old 04-15-2012, 11:27 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
2. what is the torque on the dummy plugs and standpipe? 60ft-lbs.
3. I know the jam nut on the stc is 49 ft/lbs but what is the torque for the 2 bolts to the branch tube? 124 in-lbs.
4 What is the torque on the hpop cover? 8ft-lbs.
Thanks
Answers in bold red font.
Old 04-16-2012, 05:48 AM
Quote:
Truck is a 2005 F-250. Yes I am doing the stc update as well as new oil cooler, bulletproof egr cooler, turbo feed and drain tubes
And I have no clue how to add the truck to the signature at the bottom of posts
Old 04-16-2012, 06:28 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
You need a minimum of 25 posts before you can create a "signature". When you reach 25 posts, plus 24 hours, an Edit Signature option will appear in your User Control Panel. Use that to create your sig.
upgrade standpipe on one side? hawkco66 6.0L Power Stroke Diesel 1 01-11-2017 02:55 PM
no start cookingguy 6.0L Power Stroke Diesel 13 02-01-2015 09:49 PM
Standpipe and dummy plugs Jarhead97 6.0L Power Stroke Diesel 5 10-23-2012 09:38 PM
Injector Cup Shaneb75 6.0L Power Stroke Diesel 15 03-18-2012 05:29 PM
Question about the updated standpipes and dummy plugs. ROBBINthaHOOD 6.0L Power Stroke Diesel 1 11-11-2011 03:19 PM
Tags
2006, 60, diesel, dummy, f250, install, installation, oil, pipe, plug, stand, standpipe, standpipedummy, torque, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
