Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 04-15-2012, 06:34 PM
watch129 watch129 is offline
Garage is empty, add now
watch129 is starting off with a positive reputation.
Won't restart after warmup
I have a 1985 F250 with the 300 inline 6. I replaced the head gasket and intake and exhaust gaskets and also the carb to intake gasket. Now the truck will run for a little while but as soon as you cut it off it won't restart. I replaced the fuel pump but still hasn't helped. Any theories?
  #2 (permalink)
Old 04-15-2012, 07:21 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
The problem only happens when the truck is hot?
It runs and starts ok when it's cold?
Does it run ok when it's hot before you stop it?
Check for proper choke operation, vapor lock, partially plugged fuel filter etc...
Also check to see if it's not starter drag due to hot starter etc...
  #3 (permalink)
Old 04-15-2012, 07:46 PM
Yes only when it's hot. it starts great and runs great when cold. It runs good and then starts getting sluggish and will stall after a while. It has a throttle body carb just replaced the fuel filter, fuel pump and starter.
  #4 (permalink)
Old 04-15-2012, 08:51 PM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
Quote:
On a Duraspark II 4.9-6, we would typically belch out the response, "Ignition Module," as your symptoms are indicative of a bad ignition module (starts when cold, won't start after it's warmed up and the module is hot). I don't know if the same symptoms carry over to the computer controlled modules, but none the less...
You should have a computer controlled carburetor.
Take photos of the carburetor, of the distributor, and confirm that this has the computer behind the ashtray in-cab. Post the photo's here (so we can verify that you still have feedback equipment and not a partial Duraspark II swap).
Then...
Pull the codes from the computer (OBD 1) and tell us what codes you get.
  #5 (permalink)
Old 04-15-2012, 09:20 PM
Could it have anything to do with the TFI?
  #6 (permalink)
Old 04-15-2012, 09:29 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
ctubutis ctubutis ctubutis
Yes, it could, this is what 1983F1503004x4 is alluding to above and why he asked for all the pictures.
__________________
About the bra
  #7 (permalink)
Old 04-15-2012, 10:17 PM
It bolts directly to the distributor. I replaced it once before about a year ago. Is there anyway to redo it so that it doesn't get so hot?
  #8 (permalink)
Old 04-15-2012, 10:41 PM
ctubutis's Avatar
I think it was 1992 when Ford relocated that component to the driver's side fender up by the firewall.
It's mounted on a heat sink up there, too.
No idea what it would take to implement that in an older model....
__________________
About the bra
  #9 (permalink)
Old 04-15-2012, 10:47 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
Not sure what year it started, but adding it to an older truck requires the heatsink assembly, and the wiring harness extension. The wiring plugs into the current plug at the dist that normally plugs onto the TFI, as well as another "leg" that plugs into the dist in place of the TFI, and then goes to the relocated TFI.
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #10 (permalink)
Old 04-16-2012, 01:51 AM
kedwinh's Avatar
kedwinh kedwinh is offline
1985 Ford F-150
kedwinh is gaining momentum as a positive member of FTE.
Yep, got one like that on my 95 motor home with a EFI 460.
  #11 (permalink)
Old 04-16-2012, 09:09 PM
1981 Ford F-150
Pretty easily I would think as Ford had a retrofit kit to do just that with the older models. Most likely obsolete now though.
From what Rouge-Wulff states, I would see if the 1992-up heat sump and wiring would fit. I think it just might.
I concur, and why I ask the questions in my first post.
  #12 (permalink)
Old 04-17-2012, 06:38 AM
Could I possibly make an extension out of eighth inch plate steel to extend the tfi away from the distributor since it uses magnetic impulses?
  #13 (permalink)
Old 04-17-2012, 08:05 PM
1981 Ford F-150
no, you need to use the kit (if you can find one), or make one from a later model work.
  #14 (permalink)
Old 04-17-2012, 11:30 PM
kedwinh's Avatar
1985 Ford F-150
I think you probably could. You'd have to make a cable that plugged into the dizzy, and sealed the opening. Then mount the TFI module away from the heat. In fact, I think if you google it I read somewhere that had a writeup on doing just that. I know I plan to do that with mine, somewhere down on my TO DO list. If you check around the junkyards you should be able to find one mounted on the heat sink. They used them at least up till 95 because that's what my RV is.
  #15 (permalink)
Old 04-18-2012, 11:29 AM
One great source for finding this "relocation kit" is ranger/bronco II/areostar with a 2.9L V6.
IIRC, this engine was the first one to get the kit, as the dist is at the rear, where there is more heat and less airflow.
__________________
Tags
1986, 54, f150, ford, relocation, start, tfi, warm, warmed, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
