Half a FICM
Hello Guy’s, New to the forum & the diesel world, in need of a FICM; no start & misfiring. Volts before cranking 48 and volts while cranking 48. After starting truck with a squirt of starter fluid. Scanner showed all 8 injectors misfiring. Days later i got a hold of a loaner FICM, truck started right up re-scanned it all 8 injectors functioning properly. Will a FICM half shell fix this issue or these symptoms of a bad processor board and not the converter board of the FICM? Any suggestions / ideas will be greatly appreciated, Thanks! <O</O
He said that he has 48 Volts and that it starts after a squirt of starter fluid
So that to me points at a logic problem not a power supply. I really don't
think he will get anything from replacing the Power supply in this case.
What he needs to do is some diagnostic work before tossing all the $$ at it.
That is why I said maybe not in my first post to id the half shell would fix this.
I still think it won't and that he will be tossing parts at it. The loaner FICM
worked because the logic in it was working.
Sean
Supercab
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
19
08-09-2012 07:05 AM
