Engine choice for 61 falcon ranchero - Ford Truck Enthusiasts Forums
Old 04-15-2012, 08:24 AM
Rusty36 Rusty36 is offline
Rusty36 is starting off with a positive reputation.
I have been restoring a 61 falcon ranchero and dropped a 289 in it but i also have a 96 f-150 with a 351 windsor that im thinking of replacing with a diesel. I'm trying to set my ranchero up for drags and my truck for mud bogging. Wondering if i should keep the 289 in the ranchero and rebuild the 351w and put it back in my truck or if i should rebuild the 351w and drop it in my ranchero and put a diesel in my truck?
Old 04-15-2012, 02:32 PM
parts4me's Avatar
parts4me parts4me is offline
parts4me is starting off with a positive reputation.
What originally did you have in the ranchero before the 289? And is it a basic or a high performance? Last question is what kind of transmission are you running, a C-6? The 351W would be a lot more heavier that would drag down your time if you are considering that kind of things.
Old 04-16-2012, 03:13 AM
Originally my ranchero had the straight six in it. I love speed and performance and I wasn't feeling the three on the tree much either. My dad and I took the front end and the 289 out of a 65 mustang and rebuilt that motor. We put a falcon sprint rear end in it and welded some support beams underneath connecting to the unibody. I'm not exactly sure what transmission I have in it, all I know is it's a five speed. Down the road i'm looking into putting a mustang II front end so I can cut out the firewallls for more engine clearance. Not much room left in that tiny engine compartment. So you are thinking that the 351w might just be a little too heavy for competitive racing?
Old 04-16-2012, 05:59 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The only engines available in 1960/62 Falcons (and Comets) were the 144 & 170 I-6's.
Old 04-16-2012, 06:05 AM
Im not sure which one it came with but it was an in line six. Scrapped that engine and put the 289 in.
Old 04-16-2012, 02:07 PM
parts4me's Avatar
Personally I don't think as of right now with out some good fabrication if there is enough room in your engine compartment for a 351, I think a 289 tricked out would do fine with the size of your ranchero.
Old 04-17-2012, 12:44 AM
Thanks pulls my car around pretty damn well even right now. Think only mod my dad did on the engine is a nice cam and carb. What mods would you do to the 289 to increase the power?
Old 04-28-2012, 10:05 PM
parts4me's Avatar
There are multiple ones you can do that are simple
1. Adding a cold air intake
2. Racing headers that are smoother inside reducing back pressure
3. Put a supercharger on the cold air intake
4.Switch the engine's head with one that has multiple intake values and exhaust valves. Most standard engines only have one of each. With multiple valves, the engine's airflow will increase and the horsepower will improve
5.Install an intercooler. Cool air contracts, which means you can fit more of it into the engine's cylinder than hot air. The more air you fit in the engine, the more horsepower when the cylinder fires
6. Replace your intake manifold with one made of smoother material, or simply polish it to buff out any imperfections. That will lower the air's resistance as it moves into the engine's pistons and increase its effective horsepower.
7. Increase the size of your car's air filter or reduce the size of its intake piping. This allows air to enter the engine more freely, which lets the pistons work more efficiently and increases the engine's horsepower.
Pretty much matters how much money you are willing to drop.
Old 04-29-2012, 12:04 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
You've got some of the basics here, but as far as multiple valve heads for a SBF, you'll find those in a museum, unavailable at any price.
This would be an example:
Ford GT40 4 cam 255 indy engine | GT40 ArchivesGT40 Archives
You can't just pop a supercharger on a cold air intake either. Superchargers or turbos on this type of engine require a blow-through carb set up.
Headers, intakes, low restriction air cleaners and mufflers, yes, those reduce pumping losses and increase volumetric efficiency, which leads to more power.
Old 04-29-2012, 12:07 AM
Quote:
The 289 out of the '65 Mustang....What was it originally? A 2bbl or 4bbl?
The cam, do you have any specs on it?
What size carb, and what manifold?
What exhaust?
What budget?
If you have $10,000 to play with, a 500+ horse 331 or 347 will bolt right in where that 289 is, as long as it's a 6 bolt bell.
1966 FE Ranchero/Falcon/Fairlane 73 fourxfour Ranchero & 1961 - 1967 Econoline 11 03-03-2015 02:13 AM
351W swap in a 63' Ranchero? MotörheadFord Ranchero & 1961 - 1967 Econoline 5 11-03-2014 12:15 AM
1960 Ford Falcon/Ranchero Power Steering?!? Ranchero_Boy Ranchero & 1961 - 1967 Econoline 11 02-02-2014 09:03 PM
1958 Ranchero Gage1958Ranchero Ranchero & 1961 - 1967 Econoline 0 02-21-2012 04:51 PM
64 Ranchero compatibility Q's lgyee4 Ranchero & 1961 - 1967 Econoline 3 01-18-2012 09:46 PM
Tags
1960, 1961, 1986, 302, 50, 61, build, engine, falcon, fit, ford, parts, ranchero, rancherp, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
