did my fuel pump go out???
#47
You mentioned a few times that there was only 6V at the pump. That is no good. There are 2 wires going to the fuel pump, one is ground and the other supplies 12V, which you should see for about 20 seconds after key is turned on.
Fuse # 19 (20A) in the under hood fuse box supplies power to the fuel pump relay which then sends power to the fuel pump. There is also a fuel inertia cutoff switch located behind the passenger side kick panel which interrupts power to the pump in the event of a crash.
Chris
Chris
#48
ok, its running. here is what i did to the fuses.....
on my fuse box, the #16 slot, which is the 4th big fuse on the passenger side of the box. its a 30amp.
and the #19 slot, the 7th big fuse on that same side. its a 20amp.
Both were blown. Dont know why. One of them corrected the problem, and im not sure what the other one was for.
#53
On the back of the fuel bowl you'll see an elec plug, just unplug and put a piece of electrical tape around it. It will disable your water in fuel light also, so drain it once a month just incase of water. The heater itself is pretty much useless, and could leave you stranded if/when it shorts out....which you know already... Glad you got it fixed.
