Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-14-2012, 05:59 PM
gthiboy gthiboy is offline
Garage is empty, add now
gthiboy is starting off with a positive reputation.
should I buy it? or build mine?
this is in a local classified. I have not contacted the as of yet.
"330 HORSEPOWER 390 FORD ENGINE. 8000 MILES ON REBUILD. BUILT TO SPECS OF 63 FORD 390 WITH 330 HORSEPOWER WITH HARDENED SEATS IN HEADS FOR UNLEADED FUEL. RUNS EXCELLENT. ALSO HAS ALUMINUM PERFORMER HIGH RISE INTAKE AND HOLLY 4 BARREL CARB. RAN EXCELLENT JUST PULLED TO RESTORE CAR FROM FRAME UP AND DECIDED TO GO ANOTHER ROUTE. HAS DUAL PATTERN MOTOR MOUNTS SO WILL FIT EARLY OR LATE MODEL CAR OR TRUCK. EQUIPPED AS PICTURED. ENGINE BORED .040 WITH THICK CASTING BLOCK THAT CAN POSSIBLY BE BORED TO 428 SPECS. ACORDING TO MARK ON REAR OF BLOCK THE CX IS SAME MARK AS 428 INDUSTRIAL BLOCK."
here is what I got, 1975 F250 auto 4X4 with a 390 4 barrel. when I got the truck it had a ton of vacuum leaks and I was not for sure it was a 390 so me being me I pulled it apart and confirmed it was a 390. well now I got the engine apart and not sure which way to go. If I build mine it will cost more but i'll know what is in it and how it was put together if I buy a complete engine like the one above, it may save me some cash and I can have my truck running by the end of the month.
  #2 (permalink)
Old 04-14-2012, 06:05 PM
oh yeah. If I build mine im getting rid of the 410 pistons and im gonna need to buy another head. I got a street master intake. Im not gonna make a hot rod just a good healthy runner (that can wake up the neighbors down the street) he wants $650
  #3 (permalink)
Old 04-14-2012, 06:44 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
A price would be nice unless I missed that.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #4 (permalink)
Old 04-14-2012, 08:25 PM
Quote:
Asking $650
  #5 (permalink)
Old 04-14-2012, 09:33 PM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.
it's a no brainer.
Buy the $650 engine and install it. Drive the hell outta it.
save up your money in the meantime and build a 445ci 500hp/500ft lb monster street machine over the next few years.
the recipe for success:
Ford 390 FE - Car Craft Magazine
you might want to go a little lighter on the camshaft however.
__________________
-76 F100 390FE
-63.5 Galaxie 500 -429cj
  #6 (permalink)
Old 04-14-2012, 09:36 PM
on another note, check on the block casting date. Might be a little bit of trouble fitting a 63 engine in your 75 vehicle. I have heard there are problems with taking the older engine into a newer vehicle... I never tried so I don't have any first hand knowledge.
__________________
-76 F100 390FE
  #7 (permalink)
Old 04-15-2012, 07:48 AM
baddad457 baddad457 is offline
baddad457 has a good reputation on FTE.baddad457 has a good reputation on FTE.
Quote:
Guess you didn't read tha ad he posted. That's not an issue.
__________________
89 Ranger supercab-- 302-4bbl-- 4 speed 68 Mercury Monterey 390 4 bbl C-6 77 F100 400M C-6 67 Mustang fastback 427 2-4
  #8 (permalink)
Old 04-15-2012, 07:52 AM
If it's what he says it is, $650 is a steal. And even if it's just a good running engine, it's still a good deal. I'd buy it, install it as is, run it awhile then decide what you want to do with your current engine. You may just want to sell it off and recoup what you spent on the engine in the ad. You could possibly end up with a damned near "free" engine for your truck.
__________________
  #9 (permalink)
Old 04-15-2012, 08:05 AM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
1968 Ford F-100
MIKES 68 F100 is gaining momentum as a positive member of FTE.
yup if it's what he says $650.00 is a great price
like others said then you can build a crazy 390 with your original motor .
__________________
390
10:1 C/R
Lunati 62001 cam kit
home ported heads/Flotech headers
Edelbrock performer intake /Holley 750
  #10 (permalink)
Old 04-15-2012, 08:32 AM
Quote:
doh! I read the ad 5 times and somehow or another totally missed that line. Cool, good to go.
__________________
-76 F100 390FE
  #11 (permalink)
Old 04-15-2012, 05:30 PM
found this. I called the guy and am gonna go check them out tomorrow night.
Both for $400
Trying to sale 2 ford 390's for my dad. 1st motor is a crate motor that he had bought from a freind of mine. My freind half *** put it together and put about 60,000 on it in a 75 Highboy before selling it still ran good, just dirty(oil leaks). The 2nd motor came out of my brothers Highboy. It is bored .30 over, mild cam, highrise intake, mallory distributor crome valve covers. Was a very strong and good running motor when we pulled it. Any questions, feel free to call.
Tags
1975, 390, 63, buildmine, built, buy, complete, crate, engines, ford, mine, ram
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
