Dash gear indicator - Ford Truck Enthusiasts Forums
Dash gear indicator
Old 04-14-2012, 06:47 PM
keywest keywest is offline
keywest is starting off with a positive reputation.
Dash gear indicator
Brand new 150 STX 4X4 with tow package. When first bought dash indicated change of each gear, 1 through 6 . Today I only see that it is in drive. What did a touch?
Old 04-14-2012, 07:55 PM
loydmeeks's Avatar
loydmeeks loydmeeks is offline
loydmeeks is starting off with a positive reputation.
Try shifting with your plus/minus button. That should make it show up. Also the steering wheel reset with up and down right left should find it to.
Old 04-15-2012, 12:31 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
"Owners manual" is always a good place to start.
Old 04-15-2012, 05:14 PM
cdmm151 cdmm151 is offline
cdmm151 is gaining momentum as a positive member of FTE.
Press the upper button and they will illuminate. With them showing they should appear every time you restart the engine. If they don't you will have to have the ECM flashed. It goes to the last way it was set. Mine used to only come on when I manually called for them to show until I saw my brothers come on all the time. I took it to several dealers and they said that is the way it's supposed to be. BS I said. I finally told them to flash the EC M anyway and lets see what happens. Guess what it works like I said it would.
Old 04-15-2012, 05:54 PM
I am not use what you mean when you said the upper button. Are you referring to the manual shift on the shift arm? If so, which way to you move the button? Push toward the - or the +
Thanks
Old 04-15-2012, 06:00 PM
mapitts66 mapitts66 is offline
mapitts66 is gaining momentum as a positive member of FTE.
Not one to try to hijack a thread, just popped into my mind. On the 2010's ( I guess it is the same from 2009 - 2012 ) why is the gear selected to drive in, oh let's say D for drive, highlighted in uh-oh orange and not green? Drives me nuts.
Old 04-15-2012, 06:16 PM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Quote:
Odd I would think the orange should be for neutral and the drive gears be green.
Old 04-15-2012, 09:06 PM
Quote:
Exactly. I hate driving and seeing that constant orange glow around "drive". Green would have been a much better color.
Old 04-16-2012, 08:24 PM
Doesn't matter. once illuminated they should reappear every time.
Old 12-31-2012, 05:57 PM
rtrahan rtrahan is offline
rtrahan is starting off with a positive reputation.
Quote:
Thanks
When driving normally in D simply priess the + button and the gear indicator will come on and stay on unless you press the - button. I really like this feature to have the gear indication both in Manual and Drive.
Old 12-31-2012, 07:04 PM
Northroadak Northroadak is offline
Northroadak is starting off with a positive reputation.
That button comes in handy for locking out 5th and 6th gears on occasion too.
Old 01-01-2013, 03:42 PM
FORD COASTIE's Avatar
FORD COASTIE FORD COASTIE is offline
FORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to allFORD COASTIE is a name known to all
I completely forgot about this option until I saw this thread. Turned it on when I was out and about while ago. Cool option.
Gear shift indicator 1L243 1999 - 2003 7.3L Power Stroke Diesel 2 07-01-2014 03:04 AM
Gauge cluster? Mazz 2007 - 2014 Expedition & Navigator 3 05-22-2014 08:56 AM
Gear Indicator and Gear Letter Misaligned makthenif 1997 - 2003 F150 5 02-14-2014 04:42 PM
2011 Ecoboost Transmission Gear Indicator jade97 2009 - 2014 F150 9 06-29-2011 11:09 AM
Dash swap 1986 xirxious 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-12-2009 08:02 AM
Tags
03, 1999, 2011, 2012, dash, display, drive, escape, explorer, f150, ford, gear, gears, indicator, positions, raptor, selects, svt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
