Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 04-14-2012, 05:43 PM
Stephanie Adkins Stephanie Adkins is offline
Garage is empty, add now
Stephanie Adkins is starting off with a positive reputation.
Help me please!!!!!!!
Ford F-150 1991 302 motor 4 wheel drive truck will start then will die straight out got fuel pressure tested and it was low so put a new fuel filter in it and it is still doing it any ideas on how to fix this problem any and all suggestion will be appreciated!!!!
  #2 (permalink)
Old 04-14-2012, 07:08 PM
Ddaybc's Avatar
Ddaybc Ddaybc is offline
1994 Ford F-150
Ddaybc is starting off with a positive reputation.
Quote:
Stephanie if ur truck has dual tanks make sure ur switch is set on the tank with fuel in it. I know as I had the same symptoms nd mine was on the wrong tank. Also, re-test ur fuel pressure with the new pump. Some of our trucks come with a low pressure pump (in the tank) and then a high pressure one at the fuel rails. However I don't know when that was started by Ford. I think ur 91 only had the tank pump(s) but I am not sure. I hope someone else can clarify for u. I hope this gives u a place to start. My knowledge is pretty limited.
  #3 (permalink)
Old 04-14-2012, 07:23 PM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
Low fuel pressure most of the time would mean that you have a bad high pressure check valve in the other tank then the one you are running on. This would also mean the the tank that you are not running on is filling with fuel.
You do have two tanks yes, no?
Are you only using one tank if you have two?
Who check the fuel pressure and how did they check it?
Yes a 1991 F-series only has the high pressure pump in the tank and none on the frame.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #4 (permalink)
Old 04-15-2012, 12:56 PM
just one tank guys
it just has one tank, we have checked the coil its good we have replaced the module also so it is good and it still won't fire what could it be now !!!!!!
  #5 (permalink)
Old 04-15-2012, 01:09 PM
subford's Avatar
I have my doughs on the low fuel pressure.
Who checked the fuel pressure and how did they check it?
When these fuel pumps run they will put out about 100psi into a closed head.
The Fuel Pressure Regulator (FPR) will reduce it down to around 30-34psi at idle and 40-45psi at full throttle. The spring in it will hold the pressure at 45psi but with the engine running vacuum is supplied to counter the spring and at idle the vacuum is enough to reduce the pressure down to 30-34psi depending on the vacuum reading.
The spring could be weak in the FPR but other than that and the fuel filter there just is not anything else that could do it other than a pinched fuel line from the tank to the fuel rail or low voltage.
__________________
subford@gmail.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
