Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 04-14-2012, 04:43 PM
Larry DeChant Larry DeChant is offline
Garage is empty, add now
Larry DeChant is starting off with a positive reputation.
info needed
Hi, my name is Larry and i just bought a 1993 5.8 4x4 f250 and need to know if it matters what octane of gas i run for the best gas mileage. if there is any sites where i can get tech info about how often do i do a tuneup what type of oil is good, spark plugs to use ect. thank for the help in advance.
Larry
  #2 (permalink)
Old 04-14-2012, 04:51 PM
cckruse31 cckruse31 is offline
1995 Ford F-150
cckruse31 is starting off with a positive reputation.
Hey Larry
If you have the owners manual which I doubt with a truck that old it would tell you. Otherwise just search it on google. I would assume 87 since that is usually the normal. Far as oil I would get some kind of highmilage kind that is suppose to help clean up the engine some since it is a 93. I leave the tune up and spark plugs to others, i know there are some specific spark plugs you will want but i dont remember which they are .
Colton
  #3 (permalink)
Old 04-14-2012, 07:23 PM
Ddaybc's Avatar
Ddaybc Ddaybc is offline
1994 Ford F-150
Ddaybc is starting off with a positive reputation.
Hi Larry. I have a 94 with the 5.8 nd I run 87 octane. I have the owners manual (strangely enough) nd that's what it calls for. High mileage oil is a good idea, just ensure u use high quality stuff. I use Castrol GTX. Lots of us here on FTE use copper plugs, some use platinum and very few use iridium. Whatever u do use a high quality rotor, distributor cap and the best wires u can afford. Keep #7 nd 8 as far from each other as u can so they don't fire by induction. Change oil when u want but certainly no longer than 10,000 kms. Use quality filters, avoid Fram. That's about it. Good luck.
  #4 (permalink)
Old 04-14-2012, 07:56 PM
Thank you
thank you very much for the help, it is very useful
  #5 (permalink)
Old 04-15-2012, 12:02 PM
oldmongo's Avatar
oldmongo oldmongo is offline
oldmongo has a very good reputation on FTE.oldmongo has a very good reputation on FTE.oldmongo has a very good reputation on FTE.
Hey Larry, if you get a chance to go thru these threads look for an post on a "sixliter tune up". It works well on a 5.8... as for the better filters NAPA/WIX, CARQUEST and MOTORCRAFT ... NAPA sells one # 1773 for the 5.8, it holds an extra 1/2 qt of oil ... Carquest has it too under another number. Just my $.02 worth, I ALWAYS start my oil refill with a qt of Lucas !!! ... Dave
__________________
1990 F250,Custom, Ext. Cab w/351w, ZF 5-42, 3.55 (4x1 open diff) and only 218,000 + mi. 3G ALT, 265*75*16's on 16X10 Eagle alloys , 6 Liter tune up, 98 Windstar E-fans DONE... My physical limitations made me sell my truck, but didn't remove it from my heart !!!
"IT'S DEPENDABLE AS AN OLD FRIEND" ... GONE BUT NOT FORGOTTEN !!! Till next time !!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
