1989 ford f superduty 7.3 diesel - Ford Truck Enthusiasts Forums
Old 04-14-2012, 03:55 PM
Xpebrian1 Xpebrian1 is offline
Xpebrian1 is starting off with a positive reputation.
Question 1989 ford f superduty 7.3 diesel
have a slight proablum. have 89 f superduty truck withe 7.3 diesel it was starting and running fine but today when i went to start and move it when you turn the key nothing happens the starter douse not engage or make any noise acts like ther is now power to any thing both battery fully charged and connected what should i look for any help appreatchiated thanks brian
Old 04-14-2012, 04:25 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
When you turn the key to on do you have dash lights and gauges? May need to check that battery connections are clean and tight.
Also if you look on the pass side inner fender you should see the starter relay. You could jump the two big terminals on it with a wrench or similar and see if the starter then runs.
If it does then you may have a bad neutral safety switch (if auto) or bad clutch interlock switch (if manual). If auto try moving the shifter to Neutral and trying it.
Old 04-14-2012, 05:59 PM
Smile 1989 ford f super duty 7.3 diesel
got truck to startand run as it should but will need to replace the battery cables any body know of a good place to get the battery cables let me know thanks brian
Old 04-16-2012, 05:00 PM
Question
Quote:
Originally Posted by Xpebrian1 View Post
have a slight proablum. have 89 f superduty truck withe 7.3 diesel it was starting and running fine but today when i went to start and move it when you turn the key nothing happens the starter douse not engage or make any noise acts like ther is now power to any thing both batterys charged and connected what should i look for any help appreatchiated thanks brian
got it running nut problum came back both battery's fully charged 13.5 volts per battery but when i turn key on no dash lights or any thing come on but if i turn radio on it works butif i push clutch pedale radio goes ought it acts like its not getting full power evin with to good fully charged battlries what should i look for thanks alot brian
Old 04-17-2012, 08:02 AM
Not good on electrics but maybe take the lower steering column shroud off and check that the rod that connects the key switch to the ignition switch is moving properly when you turn the key.
Also there is a big bunch of wires all connected to one big terminal on the fender mounted starter relay, some are fusible links, check that they are good.
2005 F250 Superduty hard start Tori Bartlett 1999 to 2016 Super Duty 4 06-03-2015 02:28 PM
Early 99 f250 7.3 superduty surges when shifting gears Ford_7.3 1999 to 2016 Super Duty 0 10-18-2014 08:38 PM
Lifting a Excursion hochus Excursion - King of SUVs 15 07-05-2012 03:46 PM
94 F-Superduty, No throttle response heomeout 1994.5 - 1997 7.3L Power Stroke Diesel 21 12-08-2010 03:36 PM
difference in excursion and superduty exhaust wildstang Excursion - King of SUVs 3 11-25-2009 03:11 PM
Tags
1989, 73, 89, brake, change, clutch, comp, diesel, duty, f250, ford, fsuper, lights, motor, superduty, tow, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
