Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 04-14-2012, 02:44 PM
lukeg's Avatar
lukeg lukeg is offline
1975 Ford F-100
My Garage
lukeg is starting off with a positive reputation.
Power steering pulley
Searched but couldn't find the answer. I replaced my power steering pump and the pulley now has a shake to it. Did I wreck the pulley by not using the correct puller? It didn't look like there was any damage to it. Was very careful when I removed it. This shimmy has me stumped.
__________________
2004 F-350 Lariat
1975 f-100
2008 Land Rover LR2
  #2 (permalink)
Old 04-14-2012, 02:57 PM
bismic's Avatar
bismic bismic is online now
Garage is empty, add now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Was your belt in good shape? Tensioner working well?
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #3 (permalink)
Old 04-14-2012, 03:01 PM
lukeg's Avatar
1975 Ford F-100
My Garage
Belt is 3 months old, tensioner seems to be in fine working order/good preassure.
__________________
2004 F-350 Lariat
1975 f-100
2008 Land Rover LR2
  #4 (permalink)
Old 04-14-2012, 04:51 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
2003 Ford F-350
BLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud of
How did you pull the Pulley off if you didnt use a Puller?????? BFH
Whats the shimmey liike at all time while running or just when driving???
__________________
Benny
2003 6.0, 4X4 srw, short box, born on 3/28/03 Moog ball joints,DC POWER 190A ALT Duralast Goldtop batterys 10/7/2012,RECON LED SMOKE MIRROR LENS,4 inch turbo back magnaflo exhaust,no kitty, 6 in. lift, BFG 315/75r16, python remote start alarm,pioneer system2 12''subs 1600watt amps ,scangaugeII,coolant filter, blue fuel pres spring, Fresh oil cooler 6/1/11 Final Charge Cat EC-1 rated Silicate Free ELC coolant, Sinister Full egr deleate, ROTELLA T-6 5w-40syn,updatedHPO screen,updated oil filter stand pipe
  #5 (permalink)
Old 04-14-2012, 05:13 PM
lukeg's Avatar
1975 Ford F-100
My Garage
I used a run of the mill pulley puller. Then noticed the puller your supposed to use is diffrent. I'm getting burnt out working on this thing.
__________________
2004 F-350 Lariat
1975 f-100
2008 Land Rover LR2
  #6 (permalink)
Old 04-14-2012, 06:11 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
Quote:
You probably warped the pulley. You will get burned out working on any vehicle if you don't use the proper procedures and/or tools.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #7 (permalink)
Old 04-14-2012, 07:30 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is online now
2005 Ford F-350
Snuggyworm has a great reputation on FTE.Snuggyworm has a great reputation on FTE.Snuggyworm has a great reputation on FTE.Snuggyworm has a great reputation on FTE.
snuggyworm snuggyworm Snuggyworm
Quote:
good point. i'm getting burnt out jus reading bout it. lol. kidding.
__________________
Dom
2005 F-350 PSD 6.0 KING RANCH 4X4 DRW
Ravelco Plug, Updated HFCM Drain Plug, ScanGauge II, Blue Spring Upgrade, Sinister Diesel Coolant Filter Kit, Updated STC Fitting, Upgraded FICM (6/14/12), Performance Machine Mfg Complete EGR Delete kit (5/13/13), Shell Rotella ELC, Bilstein 5100 Racing Series Shock Absorbers & Steering Stabilizer, Bilstein Front Coil Springs, Magnefine P.S. Filter, Jimmi Jammers
  #8 (permalink)
Old 04-15-2012, 04:14 AM
lukeg's Avatar
1975 Ford F-100
My Garage
Yep I sure did warp it. Pulled the belt and gave it a spin....crooked as a dogs hind leg. Live and learn, won't make that mistake again.
As for tools, i couldn't agree more.
__________________
2004 F-350 Lariat
1975 f-100
2008 Land Rover LR2
  #9 (permalink)
Old 04-15-2012, 04:17 AM
lukeg's Avatar
1975 Ford F-100
My Garage
Quote:
Lol I can still laugh about it so i guess i'm not to burnt out yet
__________________
2004 F-350 Lariat
1975 f-100
2008 Land Rover LR2
  #10 (permalink)
Old 04-15-2012, 04:39 AM
bismic's Avatar
Doing things twice really gets to me also. Hang in there - it is all a learning experience anyway. Glad you found the issue.
Good call on the warped pulley Mike (69cj).
__________________
Mark
  #11 (permalink)
Old 04-15-2012, 09:15 AM
Auto Zone will lend you the proper puller free. Just put down a refundable security deposit.
__________________
173rd Abn. RVN.
  #12 (permalink)
Old 04-15-2012, 11:57 AM
lukeg's Avatar
1975 Ford F-100
My Garage
I wish we had a Auto zone around. I can't get any place around here to rent tools. The local dealership pretty much laughed at me when I asked. Said thats why they have a service department
__________________
2004 F-350 Lariat
1975 f-100
2008 Land Rover LR2
Tags
2006, 2008, 60, escape, f250, fan, ford, land, location, lr2, power, pulley, removing, rover, sale, steering, tool, warped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
