Sudden Downshift? - Ford Truck Enthusiasts Forums
Sudden Downshift?
Old 04-14-2012, 03:04 PM
Northroadak Northroadak is offline
Northroadak is starting off with a positive reputation.
Sudden Downshift?
Recently my '11 supercab suddenly downshifted from 6th to 3rd while rolling along easily at about 50mph at the bottom of a very slight downgrade. It has done this 3 times now and takes me totally by surprise every time. Has anyone else had this happen? I have an appointment next week to get it looked at, but my dealer is about 225 miles away and it's a real pain to take it in.
Old 04-14-2012, 04:06 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Do you have it in T/H? If so and you tap the brakes it will do that, but 6 to 3 sounds like an issue. Well not from 6 right into 3rd, it shouldn't be doing that IMHO. Keep us posted on what the dealer says.
Old 04-14-2012, 11:32 PM
The oilfield service company I work for in Prudhoe Bay runs a large rental fleet, and has their own Ford shop. I asked the guy there about this and he told me they had several cold weather issues with them, including one that tried to shift into reverse when going down the road. My problem was the last time I was home in February when it was still below zero here, so maybe it is due to ice and snow buildup or something. Hope the dealer doesn't want to keep it overnight.
Old 04-15-2012, 01:11 AM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
mine did this on my way home from Washington i took it straight in to ford they told me i had a bad merconik valve body? sorry spelling is way off i know. after it got changed out and re flashed it. its working OK i guess but its still relearning.
Old 04-15-2012, 12:16 PM
I work away from home, 3 weeks on and 3 weeks off, and fly to the job. When I'm gone, my sitter drives it for 3 weeks. I wonder if it's having a "learning" problem?
Old 04-20-2012, 12:06 PM
Dealer couldn't find anything wrong, and it hasn't done it since the weather warmed up. Outside temperature was around -20 when it happened, so maybe I'll have to wait 'til next winter.
Old 04-20-2012, 04:59 PM
D8chumley's Avatar
Resident smarta$$
Thanks for coming back and reporting Off topic, Ice Road Truckers is one of my favorite shows. Have you ever been on the show? And, have you ever met Maya or Lisa?
Old 04-20-2012, 06:15 PM
We get a charge out of that show, mainly because our company is one of the premier ice road builders. Most of that show takes place on the Dalton Highway, which, although a very difficult and dangerous road, is NOT an ice road. That thin ice stuff, at least in Alaska, is pure bull. The oil companies would never risk lives and that kind of money to thin ice. The roads are engineered to carry the load. Go to Peak Oilfield Service Company, click on Prudhoe Bay division, then on "Vanishing Ice Roads" video, for a look at the way it really is.
We hold the record for the heaviest load ever moved on the sea ice, one of the Alpine production modules, at 1825 tons. Yes, I've met Lisa once.
Old 04-20-2012, 06:26 PM
Old 06-01-2012, 12:34 AM
Well, it did it again today. I was doing about 57mph on a flat level stretch, steady light throttle, and bang, right from 6th to 3rd, and back up to 6th after a couple seconds. I guess we can rule out cold weather, 56 here today!
Old 06-01-2012, 04:20 AM
wow tell them about mine (post #9) and what i had done and then ask if thats a option or if they think it could be something along that line. ill have to say my truck still don't shift right but its a hell sight better after that service work was done.
Old 06-01-2012, 04:49 AM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Quote:
Obviously they brought in Maya to boost the ratings..and a few people's blood pressure! I remember the show with her walking out of the hot thermal pools.
Old 06-01-2012, 07:56 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
Quote:
since it appears to happen at random, perhaps a little more info might help people key in on what may be causing it.
which engine?
cruise on or off when it happens?
one thing that comes to mind is a grounding issue that another memeber had..... his symptoms were different, but grounding can do some seriously wierd things. (BTW, i was the one that MISSED the nail in this thread so take everything i say with a grain of salt)
http://www.ford-trucks.com/forums/11...t-problem.html
edit ...
something else just came to mind is that your mid 90's dodge products would do this when their Throttle Position Sensor (TPS) would go out. the TPS would go to Zero ohms, telling the computer that the engine is at full throttle causing the downshift..... not sure the new fords even have a TPS, being that the throttle is drive by wire ... but that's what came to mind
keep us posted
Old 06-01-2012, 10:36 AM
It's a 5.0, and always does it in the drive position. I seldom use T/H and we really can't use cruise on most of our roads. My dealer is a 5 hour drive from here(we have a local dealer with a poor service reputation), so it's usually an overnight trip to get anything looked at. Will probably be mid July before I get back up there.
Old 06-01-2012, 10:49 AM
Now that I think about it, the door lock button on the driver's door quit working over the winter. Turned out to be a corroded wire that was never properly sealed when the dealer installed the autostart. Seems like both problems happened about the same time.
Ford AOD 4-2 Downshift LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 09-13-2016 03:48 PM
AOD 4-2 Downshift LARIAT 85 1987 - 1996 F150 & Larger F-Series Trucks 5 09-07-2016 02:22 PM
Tow/Haul mode rednck21 2015+ F150 15 09-17-2015 09:54 PM
Poor MPG on '15 6.7 17 Oaks 6.7L Power Stroke Diesel 80 06-26-2015 09:47 AM
Transmission Problems erik-the-viking 1999 - 2003 7.3L Power Stroke Diesel 8 08-05-2008 08:59 AM
Tags
73, check, diesel, downshift, downshifting, engine, f150, ford, heaviest, light, load, moved, rumble, shouldnt, sudden
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
