CEL -what to do?
#31
Hopefully, that fixes it, but the TSB doesn't say anything about testing the sensors' values; it just tells them to clean it if they see any of those codes.
From the codes listed earlier, it could be any one of 3 sensors. The real question is whether they actually verified if the sensor(s) connections were full of grunge or if they were actually out of spec.
...it's the Engineer in me
All of this really makes me want to tune and delete! But want to make sure that this isn't part of something bigger that needs to be addressed within the warranty period.
#32
Well, the CEL is on again. Came back on Tuesday shortly after leaving work. Seems like this light coming on shortly after starting truck, well before the truck is up to normal operating temp. Truck is scheduled to go back to dealer on Monday. Hopefully this will be the last time. I'm thinking that this is a faulty EGT sensor causing the light to come on. Truck still runs good and doesn't appear to be making oil or anything like that. However it does regen more often since the CEL started coming on.
#33
#35
