SuperTech Filters-R.I.P.? - Ford Truck Enthusiasts Forums
Old 04-13-2012, 09:46 PM
Roger T. Pipe's Avatar
Roger T. Pipe Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
Has anyone else noticed if their local Walmart has discontinued the Supertech brand of oil filters? I was greeted with some seriously empty shelf space when I was there today. There were Frams galore, but no Supertechs. I didn't see any Motorcrafts either. Has anyone else seen this?
Roger
Old 04-13-2012, 09:57 PM
95f2504x4's Avatar
95f2504x4 95f2504x4 is offline
95f2504x4 is starting off with a positive reputation.
At my walmart they got rid of the supertech filters and started carrying purolators(thank god) ...... now to just gid rid of the fram filters lol. They still had the motorcraft filters though.
Old 04-13-2012, 10:05 PM
From what I've read, Purolator puts out a pretty decent filter. There's a Super W/M a few towns over from me...I'll have to check them out & stock up!
Roger
Old 04-13-2012, 10:16 PM
95f2504x4's Avatar
Ya they do. I actually work for Ashland/Valvoline and Purolator is the company that actually makes our filters for us.... just with Ashland/Valvoline branding on them. They are great filters and I still have yet to see any issues with them. Seen alot come through to and there is alot of really crappy filters out there.
Old 04-14-2012, 01:23 AM
oldmongo's Avatar
oldmongo oldmongo is offline
oldmongo has a very good reputation on FTE.oldmongo has a very good reputation on FTE.oldmongo has a very good reputation on FTE.
Thumbs up Filter this !!!
Stop the madness about filters, go to NAPA ... all their filters are made by Wix same people who make filters for com. diesel truck use. I have a 5.8 in mine and I use a "NAPA GOLD FILTER" # 1773 it is a longer canister and holds an extra 1/2 qt of oil. I go 5,000 mi. between changes with no ill effects. It costs a bit more but has NEVER failed 214,000+ mi ... Take it from an old retired truck driver !!!!
Dave
Old 04-14-2012, 01:30 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Somewhere on youtube there is a guy that took apart about a half dozen filters and compared what they looked like on the inside as to how many pleats there are and how well they were constructed on the inside. I believe he had the standard napa and napa gold, a fram and a K&N. The napa standard and napa gold had like a 3 or 4 pleat difference and used a metal strip to hold the filter together where the 2 ends connected, the fram filter used less pleats and had glue holding it together and it wasn't even glued together when he took it apart, and the K&N had the most pleats and used a metal strip. I think it would be interesting to pull some of those other filters apart and see what they look like too. I thought it was ironic that the fram wasn't even put together when he disassembled it.
Old 04-14-2012, 01:48 AM
oldmongo's Avatar
Davey... I have been trusting and using WIX for mmm 40+yrs with NO FAILURES. Going on what you said I would like to know who makes K&N and the quality of their filter media. That would be interesting to see
Dave
Old 04-14-2012, 01:50 AM
pintoches's Avatar
pintoches pintoches is offline
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
Had a fram come open at the seam on my pinto, never ran a fram since!
Old 04-14-2012, 02:16 AM
GNR22's Avatar
Quote:
Dave
I'm not dissing Wix or anything. I was just saying what the differences were in the filters that the guy took apart. I usually use the motorcraft filters though.
Old 04-14-2012, 02:29 AM
whiteboyslo's Avatar
whiteboyslo whiteboyslo is online now
whiteboyslo is gaining momentum as a positive member of FTE.
Quote:
Honestly, this really tells you nothing about a filter. A filter can have less pleats and still have more capacity. It all comes down to the properties of the filter media, and that cannot be evaluated by the naked eye. To do that, you need to run multipass tests per the SAE standards. And as to the side seam method for the filter, all it needs to do it seal the one end pleat to the other. Glue is fine, and depending on the filter media, can make for a better seal versus the metal side clip.
My $.02, but I do speak from the experience of being an engineer at an aerospace filtration manufacturer for a couple years.
Mike
Old 04-14-2012, 07:14 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
If you want a look at what's inside the various brands the Kinze family did a LOT of comparison.
The results are here; Oil Filters Revealed - MiniMopar Resources
And here; Oil Filters Revealed - MiniMopar Resources
Personally I run the NAPA/Wix 1515 or a Hastings if I can find one, the Motorcraft if I'm in a pinch.
Old 04-14-2012, 08:23 AM
oldmongo's Avatar
Jim, Thanks for the links on the oil filters. I just confirms for me, why I run the NAPA/WIX filter lines. When I drove truck we went 15,000 mi. between changes and changed FILTER ONLY at 7500 mi. and then topped off the oil, with no service issues. I run the NAPA GOLD #1773 a longer in size filter with a 1/2 QT oil capacity. Glad to know I can get the same filter at Carquest or use a Baldwin/Hastings when I can find them... Thanks, Dave
SuperTech oil filter Iowa F-150 2004 - 2008 F150 16 02-13-2011 06:10 PM
Rear Diff. Fluid V10_X Excursion - King of SUVs 18 04-19-2008 08:34 AM
supertech oil ford390gashog Oil & Lubrication 3 07-04-2004 03:44 PM
SuperTech vs. Valvoline gtm245 Oil & Lubrication 42 04-07-2004 07:55 PM
SuperTech oil filters gtm245 Oil & Lubrication 20 02-14-2004 10:40 PM
Tags
04, 2003, 2004, 46, 73, discontinued, f150, filter, filters, ford, number, oil, scion, super, supertech, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
