How much should it cost me?
How much should it cost me to have a dealer program my spedo to correct for larger tires.
I just put a set of F350 18" wheels and tires on my F250 and they are taller than what was on there. I want to have the spedo corrected and the only way I know of is to have the dealer do it.
Thanks
Steve
Thanks
Steve
figure 30 minutes to 1 hour of labor....when it'll take them 5 minutes
what size are the F-350 wheels? your speedo might be correct even though those tires are larger. The Superduty comes with many different sizes from the factory. So if those tires are OEM sized...you might have a correct speedo
but yeah, plan on $50-100 easy for the fix
I do have a GPS and it shows a 4MPH faster speed when the spedo reads 65mph. I'm guessing this is somewhere around an 8% difference. At this rate I would show an additional 80 miles on the odometer for every 1000 miles traveled. I'd just like for it to be more accurate than that.
Steve
Actually, your larger tires are spinning more slowely than your old tires. So you'll have 80 fewer miles on the odo for every 1,000 miles traveled.
But either way, I would just get a basic reader or programmer that allows you to make the adjustments yourself. Then you can adjust and verify all day long without multiple trips to the dealership.
Well, like so much else in my life, I got it wrong. I stand corrected, should have spent another few minutes thinking about that. Anyway I want the odometer to read right.
Steve
Don't pay the dealership for it. Odds are they won't get it exactly right and you'll have to go back and pay more if you want it right on. Instead, find someone with AutoEnginuity to do it for free or some beer, or invest in one yourself, they are very useful.
The reason I said they may need multiple tries, is I currently have 315/75r16 tires, which is pretty much a 35" tire. I went through several reprogrammings with AE and finally got it right on with something like 33.25" tire setting. I suppose with sidewall bag and tire slippage that may be accurate, but it definitely wasn't my first guess.
mayalibre
1983 - 2012 Ranger & B-Series
04-06-2010 05:44 AM
