Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-13-2012, 07:10 PM
sscarboro's Avatar
sscarboro sscarboro is offline
2007 Ford F-250
sscarboro is starting off with a positive reputation.
How much should it cost me?
How much should it cost me to have a dealer program my spedo to correct for larger tires.
I just put a set of F350 18" wheels and tires on my F250 and they are taller than what was on there. I want to have the spedo corrected and the only way I know of is to have the dealer do it.
Thanks
Steve
  #2 (permalink)
Old 04-13-2012, 09:03 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
figure 30 minutes to 1 hour of labor....when it'll take them 5 minutes
what size are the F-350 wheels? your speedo might be correct even though those tires are larger. The Superduty comes with many different sizes from the factory. So if those tires are OEM sized...you might have a correct speedo
but yeah, plan on $50-100 easy for the fix
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 04-13-2012, 09:26 PM
bunklash's Avatar
bunklash bunklash is offline
Garage is empty, add now
bunklash is gaining momentum as a positive member of FTE.
Here's what I would do. If you don't have one, borrow a friend's GPS. It will tell you your actual speed, then you can see what your speedo is reading at key speeds.
__________________
Bunky Jones, retired AF mechanic, New Jersey escapee
'02 F350 PSD 2WD Crew Cab, SRW, Short Bed, PHP tuner, 4" turboback exhaust, AEM intake, Firestone air bags, Tru Cool 4739, tranny, water and exh temp guages.
2008 Cameo 35SB3, our retirement townhouse on wheels
Happiness doesn't come from getting what you want, it comes from appreciating what you have!
  #4 (permalink)
Old 04-13-2012, 10:40 PM
sscarboro's Avatar
2007 Ford F-250
The original wheels were 17" and the King Ranch wheels I now have are 18" with 275 X 70R 16. They are about 2 inches taller than the stock tires.
I do have a GPS and it shows a 4MPH faster speed when the spedo reads 65mph. I'm guessing this is somewhere around an 8% difference. At this rate I would show an additional 80 miles on the odometer for every 1000 miles traveled. I'd just like for it to be more accurate than that.
Steve
  #5 (permalink)
Old 04-13-2012, 10:59 PM
sand_fiend's Avatar
sand_fiend sand_fiend is offline
sand_fiend has a good reputation on FTE.sand_fiend has a good reputation on FTE.
Sandfiend
I think.. If you or a friend has A.E. you can change it your self. I may be wrong, but for some reason i thought i read it somewhere...
Im sure someone will correct me
__________________
Phil, 02 F250 7.3, Auto SD 4X4 shortbed.
149k miles. 373's.Glowshift Boost, Egt and Trans Temp Gauges.Wix 6637 Airfilter. MBRP 4" Turbo Back Exhaust.DP Tuner- 60T, Decel, 80E, 60E,
A.E. Ford Bundle.
  #6 (permalink)
Old 04-14-2012, 02:49 AM
onug's Avatar
onug onug is offline
2010 Ford F-350
My Garage
onug is gaining momentum as a positive member of FTE.
Actually, your larger tires are spinning more slowely than your old tires. So you'll have 80 fewer miles on the odo for every 1,000 miles traveled.
But either way, I would just get a basic reader or programmer that allows you to make the adjustments yourself. Then you can adjust and verify all day long without multiple trips to the dealership.
  #7 (permalink)
Old 04-14-2012, 08:26 AM
sscarboro's Avatar
2007 Ford F-250
Well, like so much else in my life, I got it wrong. I stand corrected, should have spent another few minutes thinking about that. Anyway I want the odometer to read right.
Steve
  #8 (permalink)
Old 04-14-2012, 11:50 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
2000 Ford F-250
My Garage
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
It is 6% difference. Some speedometers have bigger errors leaving the factory.
I would not worry about it too much, just when you go to a dealer for something else, ask them about resetting. Adjust oil changes.
  #9 (permalink)
Old 04-14-2012, 12:28 PM
cartmanea cartmanea is offline
cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.
Don't pay the dealership for it. Odds are they won't get it exactly right and you'll have to go back and pay more if you want it right on. Instead, find someone with AutoEnginuity to do it for free or some beer, or invest in one yourself, they are very useful.
The reason I said they may need multiple tries, is I currently have 315/75r16 tires, which is pretty much a 35" tire. I went through several reprogrammings with AE and finally got it right on with something like 33.25" tire setting. I suppose with sidewall bag and tire slippage that may be accurate, but it definitely wasn't my first guess.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Icon springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac, Off Road Tech winch bumper
- ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost), Banks Technicooler, Garrett PowerMax VGT
Currently wrecked... again. Rebuild to come.
  #10 (permalink)
Old 04-14-2012, 02:18 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Agree, made this mistake back with our '05. Ended up paying them for 1 hour for their 5 minutes of work and they changed nothing. Money would have better well spent towards a tuner that can do it better.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'01 CVPI
'97 F150 5.4L
'09 F150 5.4L
Tags
07, 1966, 1999, 60, block, bronco, cost, davison, dealership, engine, f250, harley, odometer, reset, short, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
