You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I recently procured a new motor for my 1940 P/u. I anwsered an add on CL for a 302 w/C4 trans. I called the guy and he had it still so I went an dlooked at it. Now I am mechanically inclined but can't ID a motor on sight. We turned it over and it had compression so I decided to take it. It was only $200. He helped me get it on a stand and I got it to the house. My engine stand was not that great and bent from the motor being in the trailer so I couldn't tun it over to check the block number. Long story short, I replaced the bent part this weekend and onec I got the motor turned over and looked at the block number I found it to be a 351W out of a 69 Mustang. Pretty sweet!
Red
__________________
'The best prize that life offers ...... work hard at work worth doing' Teddy Roosevelt
The Garage Journal Member
Classic Trucks Member
Custom Classic Trucks Member
And Ford Truck Enthusiast
Sounds great.... I'm pulling the flathead out of my '41 and building a 5.0 H.O. roller moter (same block as the 351W). Keeping the C-4 I have backing my Flathead etc.
__________________
Steve WV Chapter Member
1941 Ford 1/2 Ton Flathead - FTE 'Ride of the Week' 10/28-11/02 2008
1934 Chebby Sedan
Good deal! I'm replacing the flathead in my '46 this summer with a small block Ford and rebuilt C-4. I love the looks of the flathead, but the demands of daily driving in SoCal call for something a bit better. Gonna wrap up the flatty and hopefully use it in a traditional type rod sometime.
__________________
Gary-
'46 Ford 1/2 ton
'07 Black F-150 XLT SuperCrew
plus a handful of other Fords
Thanks, I was attempting to convert the "302" to a rear sump and when I was putting on the new pick up, it wouldn't fit quite right, As I was sitting there staring at it, I noticed the block numbers. That's when I looked them up. Unfortunately I now have two oil.pans that won't work and don't need along with an oil pick up.
Now I have to decide on an electric fuel pump and water pump versus mechanical. Any thoughts?
I'm only the 2nd owner of my '47 so I plan to keep it bone stock right down to the dark green paint and sick yellow trim. The flathead might have its limits but it took me a lot of miles before I decided to do a full resto. I do intend to balance and blueprint the engine and maybe run dual exhaust but that's going to be my limit.
