Electric fuel pump 6.9 IDI - Ford Truck Enthusiasts Forums
Old 04-13-2012, 03:52 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Question Electric fuel pump 6.9 IDI
what electric pumps are you guys buying for you IDI's to bypass that mechanical pump? is there a brand and model number? im thinking about bypassing my lift pump and putting and electrical pump on it while im doing an injector and line install.
Old 04-13-2012, 05:41 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
many guys here run the Facet Duralift pump. they're preferred because they can suck fuel as much as 10 feet up, unlike most pumps that prefer to push not pull.
others are running a carter or airtex pump made for diesel.
anyone who has tried the mr. gasket pump has posted with bad results and short life.
personally, i have an airtex pump set up in an unusual way: its in line with the mechanical lift pump (which is less than a year old), and is wired to only run when the glow plugs are on, making it a starting aid only, for when i have air in the lines. for only running 15 seconds at a time a couple times a day, it'll last forever i'm sure.
for doing it this way, i still use the mechanical pump i just bought last year, but have a backup for starting with air intrusion, and in the event of the mechanical pump failing, i just have to bypass it and change one wire on my e-pump, and i'm back on the road. i see it as the best of both worlds, others here see it as a pointless system. you decide for your truck.
as you know, most guys who do it remove/bypass the original lift pump and have the e-pump wired up so it has power whenever the fuel solenoid on the IP has power
Old 04-13-2012, 05:50 PM
Skip1970's Avatar
when i had lift pumps fail they pump fuel into the crankcase, wouldnt your electric on just do that if the pump failed and you tried to use it to get home? or you have 2 sets of hoses?
Old 04-13-2012, 06:20 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
b-uno,
there is a button called search opposite from the new thread button. I bet you could find 8 hundred million threads on this forum with all the information about electric fuel pumps in these trucks. Plus you wouldn't have to wait hours for people to post the same stuff again and again and again...
Just saying..
Old 04-13-2012, 06:25 PM
Skip1970's Avatar
Quote:
Originally Posted by tecgod13 View Post
b-uno,
Just saying..
never heard of this button.
Old 04-13-2012, 08:46 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Old 04-13-2012, 11:28 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Well since this is up here anyway, anyone know right off what the flow on the dura lift is? Seems most electric pumps for diesels are either low volume or high pressure.
Old 04-13-2012, 11:39 PM
Quote:
Application: Refrigeration trucks, marine generator sets, diesel filtration systems, industrial applications, and other diesel lift applications. These pumps are rated for diesel fuel, gasoline, blended alcohol fuels, and fuel additives.
Solid State Reliability: Proven on many original equipment applications No electrical contacts. No bearings or diaphragms to wear out or fatigue. Endurance life almost doubles that of our nearest competitor.
Easy to Install-Easy to Service: Two bolt mounting makes installations easy. Nothing to adjust. The pump is self-priming to 120 inches (3.0 m). Vertical mounting is preferred to assure maintenance of rated pressures. The transparent housing allows for visual capability to monitor the cleanliness of the stainless steel filter.
Eliminates Vapor Lock: When properly installed on most vehicles a constant, smooth, dependable supply of fuel under pressure is assured in the hottest weather or in high altitudes.
• Self-priming with a 10 ft. minimum lift
• Transient Protection
• Check valve
• 4 hour dry run
• Self-regulating
• 33 - 50 GPH
• 15 - 9 PSI
• VCA approved EC 95/54
• State-of-the-Art Electronic
• Sealed Electronics
• Reverse Polarity Protection
• Corrosion Resistant over 100 hours salt spray
• Durable Transparent fuel bowl
• Light Weight - 3LBs at 7 1/4”
• Low Power Requirements 1.4 amp on average
• Operating Temperature Range: -40F to 180F
Old 04-14-2012, 01:21 AM
Quote:
to use it to get home, i would have to change the wiring and the plumbing. i have plenty of hose in the vehicle at all times, as i run a mobile auto repair service from this van.
changing it over to running independent isn't just a flip of a switch, it would be re-routing the wire that controls the relay for it AND bypassing the lift pump
Old 04-15-2012, 05:01 PM
drewdole drewdole is offline
drewdole is starting off with a positive reputation.
my durolift facit works great mounted under the hood too no problem yachtsupplydepot.com
Old 04-16-2012, 07:04 AM
6.9 diesel nut's Avatar
6.9 diesel nut 6.9 diesel nut is offline
6.9 diesel nut is starting off with a positive reputation.
I too have been wondering about switching to the electric lift pump. My truck starts hard, even with the block heater plugged in. It could sit for 30 min. and starting would be hard. I have no glow plugs, so I have been "Plugging in the truck". I was wondering if I had a fuel issue. Is the Electric lift pump better than the mechanical one? I'm wondering if the truck is losing its prime.
Old 04-16-2012, 07:43 AM
Quote:
What do you mean "no glow plugs"?? First thing you should do is get 8 new Motorcraft (Beru) glow plugs and figure that system out. The top two stickied threads on the forum describe the two systems. You probably have the older style unless someone replaced it.
Secondly, look up air intrusion, though I think glow plugs are your primary issue.
Electric pumps treat the symptoms, they do not fix the underlying problems.
Old 04-16-2012, 08:33 AM
Right now, Drive train is priority. I'm putting the glow plugs after the drive train(Tranny and T case). I don't mind plugging the truck in until then. I'm saying, the truck shouldn't take 5 to 6 seconds to start after sitting for 30 min, assuming the engine was running 30 min. ago and completely warmed up,either by running it or the block heater. Also, there is a small leak at the fuel pump. I'm just wondering if an electric lift pump is better than the stock pump.
Old 04-16-2012, 04:45 PM
since your lift pump is leaking, i call it JUNK. therefore, you'll be buying a fuel pump ASAP, and the only question is which type to get. considering that, the general consensus around here has been to go with the electric.
on the subject of your hard starting, an air intrusion issue on an otherwise perfect truck will start as follows: warm up glow plugs, crank engine, starts almost instantly but dies after 1-2 seconds, crank for a long time to get fuel back up there.
your problem sounds more like the glow plugs are CAUSING your hard starting.
in my van, with good plugs and not losing prime, i never have to crank for more than a second to have her running
Old 04-16-2012, 04:53 PM
Hmm, My truck will sometimes: Crank for 5 seconds, fire but not start, stumble for a second, than start with blue smoke. When it cranks, white smoke pours from the tail pipe, than goes away when it starts.
Mechanical to Electric fuel pump... Redneckrucker16 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 02-28-2014 03:49 PM
no brakes, vacuum pump issue, stranded in Prudhoe Bay Alaska. Help? genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 06-28-2013 05:36 PM
Dual electric fuel pump bypass Shmit90051 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 01-23-2013 04:34 AM
Converting 1989 F250 to electric lift pump hugger94 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 09-19-2010 07:12 PM
Engine driven hydraulic pumps galute Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 04-01-2010 11:34 AM
Tags
69, 69l, 73, aftermarket, airtex, diesel, f250, fuel, idi, lift, oreillys, performance, problems, pump, reviews
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
