bleeding brakes
A tip on bleeding by pumping the brake pedal is to only let the pedal go down no more than 1/2 way so damage to the master cyl rubber seals won't happen due to the piston traveling farther into the bore than it would under normal brake operation and into the the grunge and rust etc which will cause damage to the seals and pedal leak down after ( or fade to the floor). If you have a new master cyl this is not a concern. Good luck!
If you are going to have any paint work done you need to let your painter know that he may have to use anti-fisheye additive.
Here is a good, commons sense article on it: http://adlersantiqueautos.com/articles/brake1.html. I'm not sure that I agree with his caution about using it on booster equipped vehicles. It would take a lot of silicone brake fluid to cause significant damage to an engine, certainly more than what is contained in a brake M/C reservoir. You would be seeing serious brake failures first. Regardless it is still a good article. You can come to your own conclusions.
Yes, I have used it for over 25 years and never had any problems with damaged seals. There are lots of rumors out there but the truth is that if you live in the rust belt or a damp climate (Florida, Gulf Coast, beach communities) it is a good idea to use it. It isn't necessary in dry climates unless you are going to keep the vehicle near the water.
DeereFord300
11-29-2016 07:40 PM
quakerj
08-25-2013 11:51 PM
Talyn
09-29-2009 10:08 PM
kilog55
30
07-06-2009 08:34 PM
bigcountry1009
05-13-2009 12:09 PM
