Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 04-13-2012, 02:36 PM
2010Edger 2010Edger is offline
Garage is empty, add now
2010Edger is starting off with a positive reputation.
2010 - Edge Noise
Hello,
I have recently joined the forum. I have searched in many different ways before posting this to try and find this issue but was not successful.
I have a 2010 Edge I bought new. I have done all of the maintenance as suggested by the Ford Service Guide.
However now after driving the vehicle for 15 to 20 minutes at speeds of 110+kmh (60+mph) and then travelling for an additional 10 to 15 minutes at 80+kmh (50+mph) I notice a whining/squealing noise that increases in intensity until it drowns out the stereo and becomes unbearable. The noise will go away instantly if the brakes are applied, if you turn the steering wheel slightly, or if you pull over and allow the vehicle to rest for 5 to 10 minutes. The outside temperature also seems to have an influence on this since I have only experienced this issue during my evening drives home from work when the temperature is 14+Celcius degrees or approximately 60+ degrees Fahrenheit. It seems to be coming from the rear of the vehicle but it's really hard to know for sure from inside the cabin.
I would love to find a TSB to take to my dealer since they refuse to drive the vehicle long enough to reproduce the issue.
The vehicle mileage is currently has 65,000+ kms/40,000+Miles.
Any and all help with this is truly greatly appreciated.
Thanks,
2010Edger
  #2 (permalink)
Old 04-23-2012, 10:57 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Have you considered taking it to another dealer? How about doing a video with sound as proof?
__________________
http://www.ford-trucks.com/forums/pi...ctureid=114550
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400
http://www.ford-trucks.com/guidelines.html
  #3 (permalink)
Old 04-23-2012, 11:17 AM
I have taken it to another dealer, but no joy there either. The dealers won't drive it long enough to reproduce the issue. The video is a good idea that we have had as well. I will definately do it as soon as the issue occurs again. Thanks for your reply.
  #4 (permalink)
Old 04-23-2012, 12:17 PM
senix's Avatar
See if this helps?
Make : FORD Model : EDGE Year : 2009
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Number : SB-20725 Date of Bulletin : MAR 01, 2008
NHTSA Item Number : 10029567
Component : WHEELS
Summary :
FORD: SOME VEHICLES MAY EXHIBIT A GROWL/HOWL TYPE NOISE COMING FROM THE LEFT AND/OR RIGHT REAR WHEEL AREA. *PE
Check to Request Research. Submit below.
__________________
  #5 (permalink)
Old 04-30-2012, 06:23 PM
senix's Avatar
Quote:
Originally Posted by m.mcclure View Post
Hello, are you a member of the ford edge forum?
Me? Nope. Just pulled the info from NHTSHA
__________________
Tags
2009, edge, exhaust, ford, loud, motor, noise, rear, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
