could someone help me out with engine block colors?
on
Oh Yea just remove the v-covers should not be any oil pour out unless the valve guild seal have crack into little pieces and now plugged up the oil return end holes in the head..
Which should be cleaned out any way. Now when replacing the gasket use rtv for motors and only on the upper side of the valve covers gasket. This mostly to hold it from coming loose. I like to set them on a clean surface side by side with some weight ovre the top like a 4x4 block of wood until rtv setups.
If your going to paint the bolts even a different color or keep them in order after you've cleaned them.
I use the valve cover gasket packaging once the gasket have been removed or any cardboard and punch many x type of hold with like 1/4"-3/8 size screwdriver and push your bolts all into the x holds to hold them so you can now paint them and just leave them in this cardboard until needed..
If you put rtv on both sides of the gasket you'll play hell not to bend it when ever you try removing it next time when needed. Then only torque to 4-6lbs max.
If the valve cover have been over tighten place upside down on a hard surface and tap it flat with a small hammer until it's even with the rest of the gasket flat edge surfaces.
Orich
Orich
Well.after some research I found the red top and black bottom is how mine came down the line. I do have a couple of other questions..I need to find a sterring wheel and then the metal retainer big piece that the steering wheel shaft goes thru. I want to find some OEM If I can and have them chromed..but I have no idea where to start ...
anyone help out there?
thanks
Steve
thanks
Steve
on
thanks
Steve
thanks
Steve
orich
Steve
Well.that's just it. I dont know what I am looking for. I really don't know what "aftermarket" is avialable out there and what would fit. I would like to look at what some others have done but here again, I am having trouble finding examples on the web. I can find pictures of interiors but, no one tells what they used as that's usually not why the picture was posted to begin with...any help would help...
Steve
Steve
Thanks so much for the reply. I have done the cardboard holding trick many times before...but the "rtf" you mention?? That nomenclature is above my head this morning....
This is the color mine should be: (engine block, vcg..etc..)
Mump 0308 07 +correct Mustang Engine Paint Color+ V8 1964 289 - Photo 29737244 - How To Choose The Correct Paint For Your Vintage Mustang Engine - Mustang Monthly Magazine
Anyway..I am going to go with the red...although I have a dupli color number for the red, (I CANT FIND THAT COLOR NUMBER NOW) ...it doesn't come up when I do a search at Summit..or anywhere for that matter.. Maybe the red is so old that the numbers are not kept any more???
I know that I bought this truck , 65 ford econoline pickup out of Kansas. It was hauled there when the owner moved from California 10 years earlier. he then after moving to Kansas had the engine and transmission overhauled and he drove it spariling after that.
I just need to clean up the engine bay area and the engine and transmission's blocks and then paint everything in the doghouse.
I would think I dont need to pull the engine/trans just to clean things up correct? If I did pull them...can't it come out from the bottom??
Thanks in advance!!!
Steve Campbell
Steve Campbell
Which should be cleaned out any way. Now when replacing the gasket use rtv for motors and only on the upper side of the valve covers. This mostly to hold it from coming loose. I like to set them on a clean surface side by side with some weight onve the top like a 4x4 block of wood until rtv setups.
I use the valve cover packaging once gasket have been removed or any cardboard and punch many x type of hold with like 1/4"-3/8 size screwdriver and push your bolts all into the x holds to hold them so you can now paint them and just leave them in this cardboard until needed..
If you put rtv on both sides you'll play hell not to bend them when ever you try removing them next time when needed. Then only torque to 4-6lbs max.
Orich
Orich
on
Hmm well for this page is basically is for pickups trucks & not vans. So not many will have the info you seek. You should post in the Van page.
But we can give you general engine & chassis problems info.
Oh when replacing valve cover Gasket Only Use RTV on the upper side of the "Gasket"
Hope that clears up my other posting.
Orich
Orich
Where to Post
I have a 1965 Ford Econoline Pickup...so I thought this was the page? If not, then where do I post?
I am also trying to find these..and not having much luck what so ever. They are the hinges that my tailgate requires and I googled it and only found one link..which really surprised me..
>>>THE HINGES REQUIRED FOR THE '64 -67 E100 ECONOLINE PICKUP ARE >>>FORD OEM PART NUMBER: C1UB-8743000-B
Any help would be appreciated..
thanks
Steve
thanks
Steve
Orich
Orich
Gaskets
When I was growing up and we were racing in Tx on the weekends, I learned everything I ever wanted to know about engines..etc.. now, after all these years..I have to blow the cobwebs out of my brain just to keep up..
When you say "RTV" ..I still am at a loss...AND what do you all suggest for material when replacing gaskets? We use to use permantex or the like when changing out the VCG....do y ou all still use that stuff? Or anything at all?
I am trying to do as much as i can to this engine so i dont have to go back and redo something because i might not have tought about it at the time...I know the componets on the outside of the engine will be chromed where possible..I dont know about the air box, air cleaner.I dont know what came on the engine when new...I am still looking around though, hmm..damn, another earthquake here....I hate these things...anyway, I am going to change out the carb...just for a bit of performance..nothing to get carried away along with header..etc.. but is there or do you have pictgures of some engines that shows some cool ideas???
Thanks so much
Steve
Thanks so much
Steve
Orich
Orich
on
Thanks so much
Steve
Thanks so much
Steve
Geez you've better come out of the stone age of old skool of when we all used Indian Chief Shellac for everything then Permatex form a gasket came along. The sealer of today kind of a Slang RTV sealer a number of company's make it..
orich
#28
I remember
You can use a tube of Ultra Black RTV You can use any brand name like Permatex.
orich
orich
Anyway..the incident where I have a problem with my tailgate hinges..does anyone have any suggestions on what or where to get some other then just flat out gettin' hammers out and making some??
I have 1965 ford econoline pickup...the only tailgate parts that are offered aren't much and they are either for styleside bed or some type of other side of bed...
thanks
Stev
#29
on
YEAH...I remember those days...I reallly do.
thanks
Stev
thanks
Stev
But other part Mac's has stuff for many vehicle types.
Maybe Dennis Carpenter or NPD our other parts dealers.
orich
#30
thanks
Steve
thanks
Steve
