Firestone R4 Tech Hybrid Air-Over-Leaf Rear Suspension
#77
Not poor materials. Firestone bags have a lifetime warranty. And I have said that overall the kit is very well made.
The leak was caused by the bag being cut by the truck's frame. There is a rolled edge that is a bit sharp (sheared) and when the bag deflates and rolls upon itself it butts up against this edge.
Only time I see it doing that though is when I dump the air. The bag is about an inch away from that area when inflated.
I hope so too. But, both bags have marks indicating contact with the frame. Light contact should not be an issue. Why it cut the bag is unknown so far.
The shield you see on the exhaust was not part of the kit. It was sent to me post installation.
#78
A 2 year update
The unloaded ride is still harsh - nothing like the promises.
firestone customer service still sucks.
I have now dealt with both AirLift and firestone's customer service department.
With AirLift I always spoke to someone on the phone and always was satisfied with the level of support.
Firestone - just plain sucks.
After you finally get through to tech support you get pushed over to warranty (life time bag warranty).
From there it is all email.
They answer email at most once per day. The will not work with you if your truck is down. I had to pull my bags and take video showing the leaks before they would authorize replacements.
Being 2 years old I figured a description and video of one bag was enough. No - took a week of back and forth to get a second bag sent out after I removed it.
I asked for two of the mounting nuts because the threads on the air port fitting was so rusted I had to sawzall off the top.
No - they will not warranty the nuts - com'on - really two freak'in nuts?
I have the firestone tech r4 suspension, which means - without bags I have no suspension.
So, since we leave today for a camping trip I put a leaking bag back in because the new bag will not be here for a few days. What a PITA
BTW - I strongly recommend against the R4 system for a variety of reasons.
Ride quality
support
"not quite ready for prime time" (at least with the DRW version)
cost
side to side roll is exaggerated as your "springs" are now much closer to the centerline of the truck
It does do a good job of leveling the truck when I drop 3500 pounds of 5th heel pin weight on it. But I could have done that with standard air bags. And if I wanted auto level, standard airbags with HCV's, height control valves, could have been added.
And still no offer of assistance from Sanluis Rassani, the company that designed this system for SRW's then made some mods without testing for DRW's.
Although they at least answer emails, then blow you off.
Should have just stuck with AIrLift
Ride quality
support
cost
#79
#80
A 2 year update
Ride quality
support
cost
Ride quality
support
cost
#81
#82
Far cheaper in the end, and does the same.
One of the problems with an all air ride suspension is - well air.
If you have leaks it gets frustrating. I am in the process now of re-vamping my air system.
Got most of the leaks fixed but I just found my 5 gallon stainless steel air tank, that is mounted above the driveshaft, has welds that leak
#85
bigc1301
Toy Hauler Towing; Fifth Wheel & Bumper Pull
30
10-11-2017 06:44 AM
airoverleaf, airoverspring, brakes, cables, firestone, firestoner, ford, height, r4, r4tech, ranger, rear, reveiw, suspension, system, tech
