Headlight relays - Ford Truck Enthusiasts Forums
Headlight relays
Old 04-13-2012, 11:22 AM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Headlight relays
Hey guys, we just picked up a new work truck and sometimes the headlights will stay on, not sure if dim or brights. I am thinking its one of the headlight relays sticking. If you guys have any other thoughts let me hear em.
Also, and more important, where ARE the headlight relays in a 97 F-250?
EDIT: Gunna throw in some more info so there is no confusion. It is a early 97 F-250 heavy duty, 460, e40d 4x4 super cab long bed, etc. etc. For all intensive purposes i could call it our 94 by appearance. I just noticed the forum breaks the years down weird.
Old 04-13-2012, 12:26 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
No headlight relay. It's all in the switch.
I'd say your wire harness is melting. Happened to me in my 95. And my 94 mustang almost burned because of it.
Mustangs had a recall. Not sure if the trucks did.
Old 04-13-2012, 01:12 PM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
Is it happening with the key off or Key on?
Old 04-13-2012, 10:02 PM
donnor donnor is offline
donnor is gaining momentum as a positive member of FTE.
"Relays" for longer [bulb] life...
These trucks did not come with headlight relays but you can install a kit available from a number of sources. Using the headlamp and dimmer switches only as controls for the smaller amount of current to operate the relays offers three advantages:
1. Longer switch life,
2. Brighter headlamps,
3. Less likelihood of setting your truck on fire due to overheated wiring components.
These kits are not that expensive and are easy to install. Since you are already experiencing problems changing out both the headlamp and dimmer switches would be very much in order. Happy wiring!
dn.
F 250 meyer plow headlight wireing/headlight relays Country_boy_2007 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 02-20-2014 01:20 AM
Headlight relay. 04 59Terry Modular V10 (6.8l) 0 05-28-2013 08:40 AM
How to make factory radio not dim with headlights on mekanikman_402 1997 - 2003 F150 11 07-28-2012 10:24 PM
No headlights only dtrl superduperlooper 1999 to 2016 Super Duty 4 06-11-2012 02:40 PM
headlight relays hairyboxnoogle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-14-2012 04:58 PM
Tags
1997, 2000, 2004, 97, escape, f150, f250, ford, headlamp, headlight, located, location, realay, relay, relays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
