Universal Joint replacement 1995 F150 4WD
Old 09-04-2009, 04:32 PM
ted4420's Avatar
ted4420
ted4420 is offline
I have a 1995 Ford F150 4wd 155" WB. I would like to change the drive shaft U joints (3). I have been told to use Dana Spicer u joint and not the China junk. I would like to know the Spicer part numbers and where I can get a good price on them. Also if there are any pictures and directions of this job. Thanks, Ted
Old 09-04-2009, 06:05 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
1994 F250: 351, C6 is offline
Take them out and measure them with a caliper. Measure the diameter of the bearing cups and the distance across the joints. I would call around to stores in your area and find someone who sells them. Personally, I think it is best to buy u-joints in a store where they can be easily and quickly returned because you frequently end up with the wrong ones.
Replacing u-joints is a pretty straightforward task, a Chilton's or Hayne's manual should provide you with any instructions you need.
Old 09-04-2009, 06:31 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,215 Likes on 798 Posts
I replaced all u-joints on my '88 13 years ago with AZ standard stock u-joints and have yet to have an issue. Install them in such a way that you can grease them as needed.
Tim
Old 09-05-2009, 05:35 AM
351slug's Avatar
351slug
351slug is offline
These guys have everything you need. I got alot of parts from them with no issues. Go to the 80-96 section and look at what they have. They helped me out over the phone while rebuilding front diff. Hope this helps.
http://broncograveyard.com/
Old 11-11-2009, 04:21 PM
sn95vert's Avatar
sn95vert
sn95vert is offline
Old 04-07-2012, 10:05 PM
FlaresideF150's Avatar
FlaresideF150
FlaresideF150 is offline
It turns out the needles in my front u joint of my rear driveshaft were dust and my passenger side motor mount was torn apart so I swapped both out. I did both u joints while I had the shaft off.
Old 04-07-2012, 10:17 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
The inbound ujoint on the passenger side is a pain in the but. I ended up changing mine with it on the truck. I would definatly suggest getting a ujoint press tool for that one lol
Old 04-13-2012, 08:55 PM
FlaresideF150
It turned out the front u joint on my rear drive shaft was gone. the needles inside were dust and i also had to replace both motor mounts. everything is good now.
CountryBumkin
16
06-05-2017 02:30 PM
TexasGuy001
13
10-30-2016 08:23 AM
Dean06919
07-26-2016 09:28 PM
SUPERDUTY_08
6.4L Power Stroke Diesel
06-28-2016 05:48 PM
SUPERDUTY_08
1999 to 2016 Super Duty
06-28-2016 05:24 PM
Quick Reply: Universal Joint replacement 1995 F150 4WD
