51' F2 Bodywork
51' F2 Bodywork
Hey I have a question on how I should finish my truck off before paint. I'm going to have to spotweld a lot of plates in to patch the rusted spots along with filling in the smaller dents and creases from bigger dents I couldn't get all the way out. What is the best type of filler or body putty to spread and block sand? And is this the best method to get a good smooth surface? Thanks!
I use Evercoat Rage Extreme filler. It is one of the best (read, most pricey) but it is lightweight and NEVER has pinholes in it. Rage Gold is good too but it is a little thicker...good for vertical surfaces where you don't want it to sag. Evercoat Metal Glaze is the best for filling small imperfections and sandpaper scratches, works well on pretty much any clean surface.
Just to reiterate and add a little to what Scott said, spot welding metal patches over the rusted areas is not the proper way to make rust repairs. You need to cut out and remove all the damaged metal and solid weld in new, clean steel patches. Having a good, solid, stable base is the most important part if you want a repair that will last. Anything less and you'll run the risk of having the repair fail and having to do it over, ruining an otherwise nice restoration. Take your time and do it right the first time.
Wicked Endings
04-07-2010 08:41 AM
ap52fordf1
08-03-2009 09:55 PM
