Vacuum and ac control - Ford Truck Enthusiasts Forums
Old 04-13-2012, 08:41 AM
Jterr Jterr is offline
Jterr is starting off with a positive reputation.
Any thoughts on what to check when I can't adjust airflow(hot or cold) by turning the control. The air only comes out at window...
Old 04-13-2012, 04:53 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Go read the FAQs in the HVAC section. Is there an echo in here????
Please do NOT start new threads for the same thing....
Old 04-13-2012, 07:36 PM
If I new where the HVAC section was I would surely read it.
I was trying to refrase the first ? as I don't know how to delete it.
Sorry to cause a problem..........
Old 04-13-2012, 09:58 PM
RebColonel RebColonel is offline
RebColonel is starting off with a positive reputation.
No problem here. Just go to the top of this page and click on FAQ and then type in what you are looking for.
Old 04-13-2012, 11:32 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Jterr- the air is directed to the defrost, dash or floor by vacuum cylinders. If things dont change, you probalby do not have good vacuum. Normally you wil end up with defrost only when you loose vacuum. Read the related posts and look for vacuum leaks under the hood on the small vacuum hoses in front of glove box and motor at the firewall.
Old 04-14-2012, 09:11 AM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
My 97' Expedition I had did the same exact thing. It ended up being a cracked vacuum line near the battery. Them lines get brittle when they get old.
Old 04-15-2012, 08:30 PM
Quote:
Quote:
Thanks Guys,
Found the culprit as y'all said. Fixed and all is well.....
Cruise Control njstevens Excursion - King of SUVs 11 02-09-2012 10:38 AM
Boost controller fuzzy1626 6.0L Power Stroke Diesel 0 02-06-2010 10:48 PM
cruise control mrwrench 1999 - 2003 7.3L Power Stroke Diesel 5 10-19-2009 02:25 PM
noise control macguyver 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 01-15-2003 11:25 AM
cruse control unreng Aftermarket Products 5 12-05-2002 10:34 PM
Tags
1997, ford, hvac, ranger, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
